Home » Archived » Visual Editor (VE) » java.lang.InstantiationException
java.lang.InstantiationException [message #75550] Tue, 21 December 2004 17:00 Go to next message
Originally posted by: freudi_t.yahoo.de
Got this exception in VE when I try to use a JTable with an class that
extends AbstractTableModel. Is there a way to show this JTables in VE,
for example using a different TableModel or defining it static or ...?
Thanks Thomas
Re: java.lang.InstantiationException [message #76472 is a reply to message #75550] Mon, 10 January 2005 10:19 Go to previous message
Hi Thomas,
Can you provide more detail of the exception please ? Is there a .log
file attached with the stack trace of the error ? What you want to do
should be supported but without more detail of your exception or more
specifics of your test case it's hard to diagnose the problem. The more
detail you can give the better.
Joe Winchester
Re: java.lang.InstantiationException [message #604336 is a reply to message #75550] Mon, 10 January 2005 10:19 Go to previous message
Hi Thomas,
Joe Winchester
Previous Topic:stuff in "SWT Layouts" is standalone?
Next Topic:How to put own Components in the palette view
Current Time: Sun Aug 31 04:50:58 EDT 2025
Powered by FUDForum. Page generated in 0.02712 seconds
