| Home » Eclipse Projects » EGit / JGit » info/refs and ^{}
 Goto Forum:|
| info/refs and ^{} [message #6786] | Sat, 09 May 2009 19:23  |  |
| Eclipse User  |  |  |  |  | Originally posted by: alex_blewitt.nospam.yahoo.com
 I'm working on reproducing the info/refs from a test git repository, and I am
 missing some ^{} entries:
 6db9c2ebf75590eef973081736730a9ea169a0c4    refs/tags/A
 17768080a2318cd89bba4c8b87834401e2095703    refs/tags/B
 d86a2aada2f5e7ccf6f11880bfb9ab404e8a8864    refs/tags/B^{} <- missing this
 032c063ce34486359e3ee3d4f9e5c225b9e1a4c2    refs/tags/B10th
 d86a2aada2f5e7ccf6f11880bfb9ab404e8a8864    refs/tags/B10th^{} <- missing this
 I can see these come from lines in the packed-refs file, but when using
 Repository.getAllRefs() these aren't listed. Is there anything I can do to get
 these from Repository, or do I have to parse the contents of packed-refs to
 find out?
 Alex
| Re: info/refs and ^{} [message #6793 is a reply to message #6786] | Sat, 09 May 2009 19:42   |  |
 get
 > find out?
 As a follow-up, if I use Repository.getAllRefsByPeeledObjectId, I can find
 some entries like this:
 AnyObjectId[d86a2aada2f5e7ccf6f11880bfb9ab404e8a8864]=[Ref[r efs/tags/B5th=efee
 904c794b943a06931c76c576dd552212e8bc],
 Ref[refs/tags/B7th=a773cd2d9dbca00d08793dac0d7002a49f0428c0] ,
 However, I don't understand if this is the right one to use to generate out
 (say) B5th^{} with the parent reference. In addition, there are some entries
 (like fd608fbe625a2b456d9f15c2b1dc41f252057dd7
 refs/tags/spearce-gpg-pub^{}) which might be from a single reference in this
 map:
 AnyObjectId[fd608fbe625a2b456d9f15c2b1dc41f252057dd7]=[Ref[r efs/tags/spearce-g
 pg-pub=8bbde7aacf771a9afb6992434f1ae413e010c6d8]]
 However, I don't understand why I don't see other entries in there, like:
 AnyObjectId[d0114ab8ac326bab30e3a657a0397578c5a1af88]=[Ref[r efs/heads/e=d0114a
 b8ac326bab30e3a657a0397578c5a1af88]]
 If there were a rule, like 'only print it out for those which have two or
 more' then I could understand how to generate them; but given I don't know why
 I see spearce-gpg-pub^{} but not e^{} in the info/refs file.
 Alex
| Re: info/refs and ^{} [message #6807 is a reply to message #6800] | Sun, 10 May 2009 07:41   |  |
 > B^{} is the peeled refs, i.e. the object a tag refers to
 >> get these from Repository, or do I have to parse the contents of
 >> packed-refs to find out?
 > Repository has a peel method.
 > peeledref = repo.peel(ref); // null if problem. May be same as ref
 > peeledid = peeled.getPeeledObjectId(); // null if not a tag
 Excellent! I can now dump out the same format for the info/refs, with the
 possible exception of HEAD. If I generate the list myself for egit, I get:
 baca4a2e2ed5fd2a19a7136baba3d8b05cc15d31    HEAD
 baca4a2e2ed5fd2a19a7136baba3d8b05cc15d31    refs/heads/master
 9f0e280a3bada33978b2c0766886a25cd16994b4    refs/remotes/origin/master
 3c064161d4568dd9cf3d76c0921a19ef1bc280b6    refs/remotes/origin/stable
 8bbde7aacf771a9afb6992434f1ae413e010c6d8    refs/tags/spearce-gpg-pub
 fd608fbe625a2b456d9f15c2b1dc41f252057dd7    refs/tags/spearce-gpg-pub^{}
 (that has local commits in my HEAD, of course). If I look at the entries
 generated by git update-server-info, I get:
 9f0e280a3bada33978b2c0766886a25cd16994b4        refs/remotes/origin/HEAD
 I can filter out the HEAD (which seems to be put in there manaully by
 readRefs())
 try {
 final Ref r = readRefBasic(Constants.HEAD, 0);
 if (r != null && r.getObjectId() != null)
 avail.put(Constants.HEAD, r);
 } catch (IOException e) {
 But I don't know where/how the refs/remotes/origin/HEAD is being put in (or,
 if it's something that is to be concerned about). Obviously I'd like to be
 equivalent to what server-update-info is doing if possible; but it's
 measurable progress, at least.
 Alex
| Re: info/refs and ^{} [message #6813 is a reply to message #6807] | Sun, 10 May 2009 09:22  |  |
| Eclipse User  |  |  |  |  | Alex Blewitt wrote: > (that has local commits in my HEAD, of course). If I look at the entries
 > readRefs())
 >         try {
 > (or, if it's something that is to be concerned about). Obviously I'd like
 > to be equivalent to what server-update-info is doing if possible; but it's
 For now. don't worry. It seems like a bug in the refs reading code in jgit.
 -- robin
| Re: info/refs and ^{} [message #572751 is a reply to message #6786] | Sat, 09 May 2009 19:42  |  |
| Eclipse User  |  |  |  |  | Alex Blewitt wrote: > I can see these come from lines in the packed-refs file, but when using
 get
 > find out?
 map:
 Alex
| Re: info/refs and ^{} [message #572769 is a reply to message #6786] | Sun, 10 May 2009 06:46  |  |
 > am missing some ^{} entries:
 > this
 A ref may be peeled or not, when you get it from getAllRefs
 -- robin
| Re: info/refs and ^{} [message #572810 is a reply to message #6800] | Sun, 10 May 2009 07:41  |  |
 readRefs())
 try {
 Alex
| Re: info/refs and ^{} [message #572840 is a reply to message #6807] | Sun, 10 May 2009 09:22  |  |
 > readRefs())
 >         try {
 -- robin
 Current Time: Fri Oct 31 05:51:13 EDT 2025
 Powered by FUDForum . Page generated in 0.04218 seconds |
