Home » Newcomers » Newcomers » how to modify source build to use additional jar file
how to modify source build to use additional jar file [message #75071] Wed, 08 June 2005 00:27 Go to next message
I'm looking at modifying eclipse to make it use ICU4J collation. I've
downloaded the source build of 3.1M7 and built it with ant, and run a
sample RCP application that I wrote.
I can modify the sources to use ICU4J collation, and rebuild eclipse,
but the new copy of eclipse can't find the icu4j.jar-- I assume because
it's running on its own jvm rather than on the modified sun 1.4.2 jvm
that I compiled it with (that jvm has the icu4j.jar file in its ext
directory).
I'm not sure how to express the dependency on the icu4j jar file so that
it gets onto the bootclasspath used by the rcp sample app. Can anyone
help?
If there's a better forum to post this message in, please let me know...
Doug
Re: how to modify source build to use additional jar file [message #75887 is a reply to message #75071] Thu, 09 June 2005 01:15 Go to previous message
Hmmm, does no one have a suggestion for me?
Previous Topic:Eclipse / CVS Share Project - Import Module has no Effect (using CVSNT)
Next Topic:Cannot type close braces in the editor
Current Time: Wed Sep 17 04:57:55 EDT 2025
Powered by FUDForum. Page generated in 0.08519 seconds
