| How to use the registry with straight osgi? [message #75060] |
Wed, 18 October 2006 09:07  |
Originally posted by: wbeckwith.gmail.com
Are there any docs or examples that can demonstrate how to do this? I
have a project that I would normally just used the RCP runtime but
because of size contraints, I hoping we can stick to the plugin model by
using osgi and the equinox registry. I'm just at a loss as to how to
get started using them together.
Wb
| Re: How to use the registry with straight osgi? [message #75305 is a reply to message #75105] |
Tue, 24 October 2006 11:23   |
Hi Wendell,
In addition, if you need just a "simple" extension registry you can look at
the JUnits from the org.eclipse.core.tests.internal.registry.simple package
in the org.eclipse.core.tests.runtime bundle. The "simple" registry can be
run without OSGi, but its functionality is simplified :-). For more details,
see RegistryStrategy, RegistryStrategyOSGI, and EquinoxRegistryStrategy.
To use Eclipse registry without Eclipse, you'll need
org.eclipse.equinox.registry bundle and it's dependents including
org.eclipse.core.jobs. The org.eclipse.equinox.registry, once activated,
creates default registry which can be accessed via
RegistryFactory.getRegistry() or via IExtensionRegistry service. The default
registry is shutdown on the org.eclipse.equinox.registry shutdown.
One other thing you'll need to consider is how you are going to fill the
registry. In Eclipse this is done by processing bundle events from the
update configurator (org.eclipse.update.configurator).
Oleg
"Simon Kaegi" <simon.kaegi@cognos.com> wrote in message
news:eh8hl8$v8g$1@utils.eclipse.org...
> For an example of the registry use at just the service level you might
> take a look at org.eclipse.equinox.http.registry.
> HTH
> -Simon
> "Wendell Beckwith" <wbeckwith@gmail.com> wrote in message
> news:eh58ue$bg6$1@utils.eclipse.org...
>> using osgi and the equinox registry. I'm just at a loss as to how to get
>> Wb
| Re: How to use the registry with straight osgi? [message #75521 is a reply to message #75305] |
Tue, 24 October 2006 22:20  |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Is there a web/wiki page somewhere that I can read about the different
ways to use the registry?
Jeff
Oleg Besedin wrote:
> Hi Wendell,
> Oleg
>> HTH
>> -Simon
>>> Wb
FUDForum. Page generated in 0.48262 seconds
