| Invoking jface WizardDialog from Swing Action [message #6745] |
Mon, 28 April 2008 10:59  |
Good effort on albireo. Quick question. I'm looking through the alpha's
as I type this, but I don't see what I'm looking for.
I want to be able to invoke a jface Dialog from a swing action but am not
having any luck.
The higher level view is that I had a complex swing tree which I've
brought into an Eclipse view via a n EmbeddedSwingComposite. Everything
working fine. however:
1. from a node + context menu, I want to be able to invoke a jface Dialog
w/ eclipse wizard pages. I know I can bring in the swing wizard api via
Tim Bodreau / swingx, however I'd rather not bring in the extra jars if I
don't have to.
| Re: Invoking jface WizardDialog from Swing Action [message #6765 is a reply to message #6759] |
Mon, 28 April 2008 11:19  |
>>> Dialog w/ eclipse wizard pages.
>> You should be able to fire up your JFace dialog ( within a
>> Display.asyncExec runnable)
> Doh! I should have said from within a java.awt.EventQueue.invokeLater
> runnable.
It's a bad Monday morning, apparently. I was right the first time. Sorry.
| Re: Invoking jface WizardDialog from Swing Action [message #573986 is a reply to message #6745] |
Mon, 28 April 2008 11:15  |
Display.asyncExec runnable) from the Swing action's java code. Does this
not work for you? What's the error you are seeing?
| Re: Invoking jface WizardDialog from Swing Action [message #574009 is a reply to message #6753] |
Mon, 28 April 2008 11:17  |
runnable.
| Re: Invoking jface WizardDialog from Swing Action [message #574034 is a reply to message #6759] |
> runnable.
FUDForum. Page generated in 0.06073 seconds
