Home » Archived » XML Schema Definition (XSD) » Loading chameleon schemas
Loading chameleon schemas [message #74773] Mon, 23 June 2008 16:42 Go to next message
Some schemas use the pattern of importing (or including) a schema that has
no targetNamespace into a schema that does have a namespace (aka chameleon
schemas). When using the XSD model to load these schemas, the imported
chameleon schema definitions are added to EACH schema that imports them. I
believe that this is correct from the perspective of the XSD infoset, but it
causes problems when I want to access and process the XSD definitions as
defined in each original schema. My use case is to transform the XSD to a
UML model that reflects the original schema modularity.
Is there any way to change this behavior when loading XSD so that a
chameleon schema is loaded only once with a null targetNamespace and
imported by the other XSDSchema components? Or, lacking that, some way to
load the chameleon schema and sort out which definitions in other schemas
are actually duplicate copies?
Dave Carlson
Re: Loading chameleon schemas [message #74793 is a reply to message #74773] Mon, 23 June 2008 17:30 Go to previous messageGo to next message
Dave,
Comments below.
> schemas).
Only including has this effect.
Don't count on that. Decomposition in to .xsd files is completely
arbitrary from an abstract component point of view and the translation
is done at that level, not the syntactic level.
Not really, no. It's a complex problem to untangle the impact of
chameleon includes. They suck.
> Dave Carlson
Re: Loading chameleon schemas [message #74810 is a reply to message #74793] Tue, 24 June 2008 12:14 Go to previous messageGo to next message
Ed,
>> has no targetNamespace into a schema that does have a namespace (aka
>> chameleon schemas).
I had also thought that xsd:include must be used for chameleon schemas. But
someone recently told me that the Oxygen XML editor throws an error for
this, with a message that xsd:import should be used for chameleons. I
checked the XSD specs (both 1.0 and 1.1) and it appears that either
xsd:include or xsd:import may be used for this. The 'namespace' attribute
is omitted when using xsd:import of a schema with no namespace.
>> to load the chameleon schema and sort out which definitions in other
>> schemas are actually duplicate copies?
I couldn't agree more. I try to discourage designers from using chameleon
schemas, but some still like the idea.
Re: Loading chameleon schemas [message #74827 is a reply to message #74810] Tue, 24 June 2008 14:58 Go to previous message
--------------020300020006070009090201
Dave,
Comments below.
Dave Carlson wrote:
> Ed,
>>> chameleon schemas).
An import is just an import. The original components will be imported
with the null namespace. Only an include will do the chameleon thing.
Are you going to believe Oxygen or me? :-P
Tell them I consider it a foolish choice. Discourage the use of
redefine even more. That's so horrible I cringe at the mention of it.
<html>
<head>
</head>
Dave,<br>
<br>
Comments below.<br>
<br>
Dave Carlson wrote:
<blockquote cite="mid:g3r6hs$vto$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
</pre>
<blockquote type="cite">
<pre wrap="">Some schemas use the pattern of importing (or including) a schema that
chameleon schemas).
</pre>
</blockquote>
<pre wrap="">Only including has this effect.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
An import is just an import.&nbsp; The original components will be imported
with the null namespace.&nbsp; Only an include will do the chameleon thing.&nbsp;
Are you going to believe Oxygen or me? :-P<br>
<pre wrap="">
</pre>
<pre wrap="">imported by the other XSDSchema components? Or, lacking that, some way
</pre>
</blockquote>
<pre wrap="">Not really, no. It's a complex problem to untangle the impact of
</pre>
</blockquote>
</pre>
</blockquote>
Tell them I consider it a foolish choice.&nbsp; Discourage the use of
redefine even more.&nbsp; That's so horrible I cringe at the mention of it.<br>
<pre wrap="">
</pre>
</blockquote>
<br>
</body>
</html>
--------------020300020006070009090201--
Re: Loading chameleon schemas [message #603110 is a reply to message #74773] Mon, 23 June 2008 17:30 Go to previous message
Dave,
Comments below.
> schemas).
> Dave Carlson
Re: Loading chameleon schemas [message #603115 is a reply to message #74793] Tue, 24 June 2008 12:14 Go to previous message
Ed,
>> chameleon schemas).
Re: Loading chameleon schemas [message #603119 is a reply to message #74810] Tue, 24 June 2008 14:58 Go to previous message
Dave,
Comments below.
Dave Carlson wrote:
> Ed,
>>> chameleon schemas).
<html>
<head>
</head>
Dave,<br>
<br>
Comments below.<br>
<br>
<pre wrap="">Ed,
</pre>
chameleon schemas).
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:Loading chameleon schemas
Next Topic:Validation Error "use" parmeter
Current Time: Thu Jul 17 22:30:45 EDT 2025
Powered by FUDForum. Page generated in 0.09286 seconds
