Home » Eclipse Projects » Technology Project and PMC » API class to change plugin.xml
API class to change plugin.xml [message #74598] Sun, 10 June 2007 00:07 Go to next message
I need to progrmmatically change plugin.xml and have been looking for such
a class without success. For example, I need to add a few jar files to the
runtime classpath of the plugin.xml. Could you let me know if there is any
API class to do that?
Choudary.
Re: API class to change plugin.xml [message #74617 is a reply to message #74598] Fri, 15 June 2007 10:30 Go to previous messageGo to next message
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Choudary Kothapalli napisał(a):
> such a class without success. For example, I need to add a few jar files
> to the runtime classpath of the plugin.xml. Could you let me know if
> there is any API class to do that?
> Choudary.
There is no such thing.
If you want to manipulate loading jars, please read about equinox.
HTH
Chris
Re: API class to change plugin.xml [message #75015 is a reply to message #74617] Mon, 12 November 2007 09:04 Go to previous message
Originally posted by: jan-hendrik.diederich.bredex.de
Indeed,
a simple example implementation can be found at this enhancement:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201052.
As the attachment https://bugs.eclipse.org/bugs/attachment.cgi?id=82451.
It is simpler than the reference examples.
Re: API class to change plugin.xml [message #601444 is a reply to message #74598] Fri, 15 June 2007 10:30 Go to previous message
> Choudary.
HTH
Chris
Re: API class to change plugin.xml [message #601599 is a reply to message #74617] Mon, 12 November 2007 09:04 Go to previous message
Indeed,
Previous Topic:ACTF initial commit - help!!
Next Topic:How to scroll has been below
Current Time: Sat Nov 08 11:36:18 EST 2025
Powered by FUDForum. Page generated in 0.03162 seconds
