Home » Archived » Visual Editor (VE) » Setup Java Visual Editor
Setup Java Visual Editor [message #74535] Fri, 10 December 2004 09:46 Go to next message
Originally posted by: Jeanine.twistedpair.nl
Whenever I open the visual editor I get this error:
!MESSAGE An internal error occurred during: "Setup Java Visual Editor".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/plugin/JavaEMFNature
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1822)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1717)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1518)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
My Installation is:
EMF SDK 2.0.1
GEF SDK 3.0.1
Eclipse 3.0.1
Visual Editor SDK 1.0.2
!SESSION Dec 10, 2004 15:41:18.171
eclipse.buildId=M200409161125
java.version=1.4.2_05
What did I do wrong?
Jeanine
Re: Setup Java Visual Editor [message #74591 is a reply to message #74535] Fri, 10 December 2004 18:22 Go to previous messageGo to next message
> !STACK 0
> at
> at
> at
> My Installation is:
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> Eclipse 3.0.1
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Jeanine
Jeff,
I did post the same message at the VE's newsgroup, but there was no
response.
I'll hope you will reply there too.
BTW: The EMF Example plugin isn't installed and I upgraded every plugin
and feature there is, but still no success.
Jeanine
Re: Setup Java Visual Editor [message #74629 is a reply to message #74591] Mon, 13 December 2004 09:59 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
>> !STACK 0
>> at
>> at
>> at
>> My Installation is:
>> EMF SDK 2.0.1
>> GEF SDK 3.0.1
>> Eclipse 3.0.1
>> Jeanine
> Jeff,
> response.
> Jeanine
Hmm, this is strange. Please look in your eclipse plugins directory for
the plug-in org.eclipse.jem.workbench_1.0.2, and make sure there's a
workbench.jar within it. These files should have been included in the
VE-SDK zip. I'm stumped otherwise, maybe someone else from the VE team
will have other recommendations.
- Jeff
Re: Setup Java Visual Editor [message #74664 is a reply to message #74535] Mon, 13 December 2004 10:22 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Do you have the Eclipse SDK 3.0.1? You need to have the Eclipse SDK, or
at least Eclipse Runtime + Eclipse JDT. The Eclipse Runtime by itself is
not sufficient.
Rich Kulp
Re: Setup Java Visual Editor [message #74836 is a reply to message #74629] Tue, 14 December 2004 08:38 Go to previous messageGo to next message
Originally posted by: wjl12.comcast.net
Jeff Myers wrote:
>>> !STACK 0
>>> at
>>> at
>>> at
>>> My Installation is:
>>> EMF SDK 2.0.1
>>> GEF SDK 3.0.1
>>> Eclipse 3.0.1
>>> Jeanine
>> Jeff,
>> response.
>> Jeanine
> - Jeff
I'm having this problem, too. I have workbench.jar in the
org.eclipse.jem.workbench_1.0.2.
-- Bill
Re: Setup Java Visual Editor [message #74868 is a reply to message #74836] Tue, 14 December 2004 10:20 Go to previous messageGo to next message
Look at the .log file and the manage configurations dialog, make sure
there are no configuration errors. Something is not installed correctly.
Rich Kulp
Re: Setup Java Visual Editor [message #75010 is a reply to message #74868] Tue, 14 December 2004 11:17 Go to previous messageGo to next message
I went back and downloaded a clean a copy of 3.0.1 SDK, EMF 2.0.1, GEF
3.0.1 and VE runtime 1.0.2 ONLY. It works fine, so I either had the wrong
version of the EMF or GEF, or I didn't have the SDK.
frame, panel and all dessapear .... [message #78466 is a reply to message #74535] Thu, 27 January 2005 15:00 Go to previous messageGo to next message
Originally posted by: gvaldes.esval.cl
I have a problem, the VE work very good, bud after of a
time the panels (JFrame, buttons, etc) dissapear and i not can see it.
thank for all,
Re: frame, panel and all dessapear .... [message #78523 is a reply to message #78466] Thu, 27 January 2005 16:23 Go to previous messageGo to next message
Please append the .log file from the .metadata directory. There may be
errors logged that could point to a problem.
Rich Kulp
Re: frame, panel and all dessapear .... [message #78537 is a reply to message #78523] Thu, 27 January 2005 16:24 Go to previous message
I see you already got an answer in another thread on this newsgroup.
That's great.
Rich Kulp
Re: Setup Java Visual Editor [message #603838 is a reply to message #74535] Fri, 10 December 2004 18:22 Go to previous message
> !STACK 0
> at
> at
> at
> My Installation is:
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> Eclipse 3.0.1
> Jeanine
Jeff,
response.
Jeanine
Re: Setup Java Visual Editor [message #603846 is a reply to message #74591] Mon, 13 December 2004 09:59 Go to previous message
>> !STACK 0
>> at
>> at
>> at
>> My Installation is:
>> EMF SDK 2.0.1
>> GEF SDK 3.0.1
>> Eclipse 3.0.1
>> Jeanine
> Jeff,
> response.
> Jeanine
- Jeff
Re: Setup Java Visual Editor [message #603854 is a reply to message #74535] Mon, 13 December 2004 10:22 Go to previous message
not sufficient.
Rich Kulp
Re: Setup Java Visual Editor [message #603885 is a reply to message #74629] Tue, 14 December 2004 08:38 Go to previous message
Jeff Myers wrote:
>>> !STACK 0
>>> at
>>> at
>>> at
>>> My Installation is:
>>> EMF SDK 2.0.1
>>> GEF SDK 3.0.1
>>> Eclipse 3.0.1
>>> Jeanine
>> Jeff,
>> response.
>> Jeanine
> - Jeff
-- Bill
Re: Setup Java Visual Editor [message #603891 is a reply to message #74836] Tue, 14 December 2004 10:20 Go to previous message
Rich Kulp
Re: Setup Java Visual Editor [message #603899 is a reply to message #74868] Tue, 14 December 2004 11:17 Go to previous message
frame, panel and all dessapear .... [message #604864 is a reply to message #74535] Thu, 27 January 2005 15:00 Go to previous message
thank for all,
Re: frame, panel and all dessapear .... [message #604875 is a reply to message #78466] Thu, 27 January 2005 16:23 Go to previous message
Rich Kulp
Re: frame, panel and all dessapear .... [message #604879 is a reply to message #78523] Thu, 27 January 2005 16:24 Go to previous message
That's great.
Rich Kulp
Previous Topic:VE invisible....
Next Topic:VE invisible....
Current Time: Fri Nov 07 18:08:53 EST 2025
Powered by FUDForum. Page generated in 0.07182 seconds
