| minor annoyance with change method signature refactor [message #6710] |
Sat, 30 June 2007 18:02  |
am new to Eclipse newsgroups, hope this is the right place to post.
I find Mylyn a pleasure to work with. It is great that it only shows the
stuff that is relevant.
Cheers for the 2.0 release.
But I noticed a very minor annoyance when using the change method
signature refactor. I am using Mylyn 2.0 (same issue with 1.0) under
Eclipse 2.2.1 and have the following problem:
Let say you open X class for editing (opened Java Editor)
Then you wish to use the change method signature refactor, go over
method (ctrl+shift+C) the dialog pops up. And if you use ctrl+space key
on any of the type fields. Then the Java Editor at the back would get
closed. Surprising this always happens if I am editing an Interface and
rarely if a Java file.
While I rarely use change method signature refactor and didn't want to
mention this but there is nothing more annoying than Mylyn closing the
Java editor I am just using. Maybe if somebody could take a look?
Alen
| Re: minor annoyance with change method signature refactor [message #569252 is a reply to message #6710] |
Sun, 01 July 2007 02:03  |
Same (closing editor) happens when I rename field (may be also method).
I've downloaded RCP package of Eclipse 3.3 mostly for Mylyn. I've
removed XML support from it (because I have already commercial XML
editor that is better). But it seems that Mylyn is still causes problems
as it was several months ago. :-(
I see also that eclipse.exe hangs in memory when I close Eclipse. May
be this is problem of Mylyn, but may be not (I've placed .mylar in
remote folder).
| Re: minor annoyance with change method signature refactor [message #569301 is a reply to message #6719] |
Sun, 01 July 2007 16:35  |
Same problem also happens when I use Eclipse code assist to implement
methods in abstract class (Ctrl+Space) here "new Runnable(${cursor})".
> remote folder).
OK, this is really not problem with Mylyn.
| Re: minor annoyance with change method signature refactor [message #569327 is a reply to message #6725] |
Mon, 02 July 2007 07:43  |
>> May be this is problem of Mylyn, but may be not (I've placed .mylar in
>> remote folder).
My Eclipse crashed when I clicked on the radio button next to the task
name in task list. That isn't very nice. Most probably I need to
increase the heap size.
Is there a bug filed for ctrl+space problem since I probably don't need
to mention how annoying that is?
And one more thing why is not possible to add a class as landmark? For
example I will be working with SomeDAO.java and SomeBL.java, now I wish
not to wait for Mylyn to pick this up but I want to predefine this, if I
right click on lets say SomeDAO.java and select Add as Landmark I get
"Not a valid landmark" message. How can a Java file not be a landmark?
This is greately reducing my productivity since I would like to
predefine some classes I know I will need(for a particular task) in the
package explorer. Mylyn while smart as it is should listen to my needs
ahead of time and not just in time:)
Is there a bug filed for this?
Alen
| Re: minor annoyance with change method signature refactor [message #569371 is a reply to message #6731] |
Mon, 02 July 2007 08:28  |
You need to click on the class and no the file name in the
PackageExplorer. As far as I know this is stated in the documentation
for Mylin.
Stefan
>>> in remote folder).
> Cheers,
> Alen
| Re: minor annoyance with change method signature refactor [message #569384 is a reply to message #6744] |
Mon, 02 July 2007 09:32  |
> for Mylin.
Sorry to be a bit blunt: That is not very user friendly way, since
normally I would like to select lets say 4 files at once (holding ctrl)
and add them as landmark.
Surprisingly even if I select a class(not a file) I get "Not a valid
landmark" message but if I select a method within the class then it is a
valid landmark.
IMHO: Landmarking needs some refinement. While I think it is sufficient
if you are doing (minor) bug fixes it breaks down if for example you are
doing some more substantial refactoring or adding some functionality to
existing code.
I know there is (Ctrl + Shift + R (Quick open)) but I would fell much
more at ease if all the files that are revelant to me are displayed in
the package explorer(that would still reduce quite a load of files).
Alen
| Re: minor annoyance with change method signature refactor [message #569657 is a reply to message #6725] |
Wed, 04 July 2007 00:10  |
>>> to mention this but there is nothing more annoying than Mylyn closing
>>> the Java editor I am just using. Maybe if somebody could take a look?
>> problems as it was several months ago. :-(
Alex, Konstantin: If you haven't yet, could you please file a bug report
for this? I use the mechanisms that you mention very frequently and do
not see this problem, so we need to diagnose in more detail to
understand where the bad interaction is coming from.
http://www.eclipse.org/mylyn/bugs/
Mik
| Re: minor annoyance with change method signature refactor [message #569679 is a reply to message #6751] |
Wed, 04 July 2007 00:19  |
> valid landmark.
> existing code.
As Stefan points out this is technically by design, but we have
definitely noticed it get in people's way, especially when getting
started with Mylyn and relying on manual landmarking rather than the
automatic landmarking. So we need to do something about it.
The reason that files cannot be made landmarks when the structure of a
file is understood by Mylyn (e.g. as it is for Java) is that the file is
just a container for the structured elements, and we do not allow
containers to be landmarks. One consequence of allowing them to be
landmarks is that you would see a lot more bold in your Package Explorer
than would be useful. But what we could do is something like have the
landmarking operation on the file propagate down to the first element
contained within the file (e.g. the Java class declaration). Please
post your use case on the following bug, and vote for it to help us
prioritize it:
162335: Allow "Make Landmark" to work anywhere in the file
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162335
Mik
FUDForum. Page generated in 0.06213 seconds
