Home » Modeling » GMF (Graphical Modeling Framework) » How to get Diagram size in layoutProvider
How to get Diagram size in layoutProvider [message #74282] Sat, 04 November 2006 14:24 Go to next message
Originally posted by: awm_abu.yahoo.com
Hello all,
I am using a layoutProvider to create a grid like layout.
I need to put a column at the left extreme of the diagram space and one at
the right extreme also.
The left hand one is ok as I know I am starting from 0,0.
However I can't figure out the right hand side one.
I was thinking to get the figure used for the diagram and call getClientArea
on it.
However I can't figure out how to get that info into the layoutprovider
class.
Can anyone help ?
Thanks.
Re: How to get Diagram size in layoutProvider [message #74639 is a reply to message #74282] Mon, 06 November 2006 09:50 Go to previous messageGo to next message
There is a helper method on the DiagramEditPart called getChildrenBounds
the method will return the children bounds (based on the current bounds
of the figures)
Alan wrote:
> Hello all,
> on it.
> class.
> Can anyone help ?
> Thanks.
Re: How to get Diagram size in layoutProvider [message #74807 is a reply to message #74639] Mon, 06 November 2006 13:07 Go to previous messageGo to next message
Thanks for getting back to me.
How do I get a handle on the DiagramEditPart.
My class is called GridLayoutProvider and extends
AbstractLayoutNodeProvider.
The two methods are
public Runnable layoutLayoutNodes(List layoutNodes, boolean
offsetFromBoundingBox,IAdaptable layoutHint)
and
public boolean provides(IOperation operation)
I can't see obviously how to get a handle to the DiagramEditPart.
I can get the Diagram as:
ILayoutNode lnode = (ILayoutNode)li.next();
NodeImpl node = (NodeImpl)lnode.getNode();
Diagram di = node.basicGetDiagram();
But still can't seem to figure how to get the DiagramEditPart from here ?
Any thoughts ?
"Mohammed Mostafa" <mmostafa@ca.ibm.com> wrote in message
news:eini62$f2g$1@utils.eclipse.org...
> the method will return the children bounds (based on the current bounds of
> the figures)
> Alan wrote:
>> Hello all,
>> at
>> getClientArea
>> on it.
>> class.
>> Can anyone help ?
>> Thanks.
Re: How to get Diagram size in layoutProvider [message #75455 is a reply to message #74807] Tue, 07 November 2006 11:24 Go to previous messageGo to next message
try :
IGraphicalEditPart gep = (IGraphicalEditPart) layoutHint
.getAdapter(IGraphicalEditPart.class);
if (gep!=null){
Map registry = gep.getViewer().getEditPartRegistry();
// then get the diagram object some how
EditPart diagramEditPart = registry.get(diagram);
one comment though; avoid using the NodeImpl use Node instead
and use getDiagram instead of basicGetDiagram()
Frank Abercorn wrote:
> The two methods are
> and
> Any thoughts ?
>> the figures)
>> Alan wrote:
>>> Hello all,
>>> at
>>> getClientArea
>>> on it.
>>> class.
>>> Can anyone help ?
>>> Thanks.
Re: How to get Diagram size in layoutProvider [message #75576 is a reply to message #75455] Tue, 07 November 2006 14:24 Go to previous message
Thanks a lot that seems to have done it.
news:eiqc34$2vf$1@utils.eclipse.org...
> try :
> if (gep!=null){
>> The two methods are
>> and
>> Any thoughts ?
>>> of the figures)
>>> Alan wrote:
>>>> Hello all,
>>>> at
>>>> getClientArea
>>>> on it.
>>>> class.
>>>> Can anyone help ?
>>>> Thanks.
Previous Topic:Changin the palette background and foreground colors
Next Topic:How can I refresh the diagram when properties change, that aer shown as labels in the diagram
Current Time: Thu Nov 13 16:47:01 EST 2025
Powered by FUDForum. Page generated in 0.04193 seconds
