Home » Archived » BIRT » Build my own Birt
Build my own Birt [message #74273] Wed, 14 September 2005 23:23 Go to next message
Originally posted by: sas.sas.com
Hello!
I follow the instructions presents im
" http://www.eclipse.org/birt/index.php?page=build/build_instr .html" to
compile my own Birt, but din't work...
Someby knows if exists others instructions to build Birt???
Thanks!
Re: Build my own Birt [message #74381 is a reply to message #74273] Thu, 15 September 2005 09:38 Go to previous message
Hi Daniel,
Not sure if this helps, foe me I couldn't get some things to build under
3.0.2 so I moved to 3.1 and had better success building
(though the test plugins still don't build for me)
Also note that the ODA plugin is now found here. (I copied info below)
To all developers that work with the BIRT source tree:
As part of the BIRT 2.0 project BPS30: ODA Framework Migration to DTP
(described in BPS project spec:
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS30), BIRT has been
changed to adopt the DTP ODA run-time framework. The related source is
committed to CVS earlier tonight.
So to compile the latest BIRT source tree in your workspace, you will
need to get the DTP ODA source tree from the Eclipse CVS repository for
the Data Tools Platform (DTP):
Host: dev.eclipse.org
Repository path: /home/datatools
ODA folder:
HEAD/org.eclipse.datatools.connectivty/plugins/org.eclipse.d atatools.connectivity.oda/
good luck to ya
Daniel wrote:
> Hello!
> Thanks!
Re: Build my own Birt [message #74470 is a reply to message #74381] Thu, 15 September 2005 00:32 Go to previous message
Mike,
The instructions on that page should work for the 1.0.1 source.
Were you compiling the latest or version 1.0.1?
Jason Weathersby
BIRT PMC
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:dgbthf$2fk$1@news.eclipse.org...
> Hi Daniel,
> So to compile the latest BIRT source tree in your workspace, you will need
> to get the DTP ODA source tree from the Eclipse CVS repository for the
> ODA folder:
> good luck to ya
> Daniel wrote:
>> Hello!
>> Thanks!
Previous Topic:Report going out of the page when trying to view in PDF
Next Topic:Problem connecting width db2 V8.1
Current Time: Tue Jul 22 13:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.06178 seconds
