Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo plan to support java5 annotations instead of EMF?
Teneo plan to support java5 annotations instead of EMF? [message #74257] Thu, 08 March 2007 09:44 Go to next message
im really just a newbie to teneo, EMF and EJB3 but i was wondering about
this:
i was just reading about the new proposed eclipse project DALI which if i
understand correctly, will assist in mapping of EJB3 persistence in code.
From what I understand about EJB3 is that it uses java 5 annotations to
define mapping of them model and that it is the JDK standard for persisted
entities.
Teneo uses EMF model annotations, which are NOT java 5 annotations. Is
there a particular reason for not using Java5 annotations? Does the Teneo
team envision eventually switching to annotations eventually? or at least,
support them too?
and if Teneo remains with EMF annotations, what will be the impact of
being incompatible with the 'EJB3' standard and the tools that will be
developed for it?
thanks for helping me understand your vision and i really think teneo
rocks!
Re: Teneo plan to support java5 annotations instead of EMF? [message #74546 is a reply to message #74257] Thu, 08 March 2007 20:17 Go to previous messageGo to next message
Hi Jean-Denis,
All valid questions.
First what we will not do (at least not in the foreseeable future): Teneo will not generate java 5
annotations in the source code. The source code generation is handled by native emf and not by Teneo
and native emf does not know about persistence. Teneo will neither provide custom code generation
templates to get this solved. The reason for this is that this is a great amount of work and would
not necessarily work if users also have their own templates. Also (but this is my personal opinion)
I am not that much in favor of adding jpa annotations (with for example column/table names) in the
java code. I think it is nicer if this is specified separately (as allowed by the jpa/ejb3 spec in
a separate xml file). But I fully understand that views on this differ.
Then what we will do/already do related to following the standard:
The jpa/ejb3 spec also allows annotations to be specified in xml. Teneo currently also allows you to
specify annotations in xml. This xml follows practically the same standard as ejb3/jpa (with some
additions for usability). Also the annotations in the model follow the jpa/ejb3 standard.
Currently teneo generates hbm and jdo xml files. In the short future we will add support for
generating ejb3/jpa xml files which follow the standard exactly. This jpa/ejb3 mapping file can then
be edited (with tool support) in the dali tools environment. This supports a so-called
meet-in-the-middle scenario (for which the dali tools are an targeted afaics).
Teneo has two specifics (which are different than jpa/ejb3):
- Teneo supports automatic mapping of your model to a relational model. With Teneo you only need to
specify annotations to override default behavior while the jpa/ejb3 spec specifies that annotations
are mandatory. So even if you don't annotate your model Teneo will still map it to the db (and
generate a hibernate/jpox and later ejb3/jpa mapping file).
- With teneo not the java class/members are mapped to the relational database but the model is
mapped to the relational database. This allows support for dynamic emf. At runtime teneo resolves
the model to actual implementation classes (or uses dynamic emf).
gr. Martin
Jean-Denis Boudreault wrote:
> Hello,
> this:
> i understand correctly, will assist in mapping of EJB3 persistence in
> code. From what I understand about EJB3 is that it uses java 5
> annotations to define mapping of them model and that it is the JDK
> standard for persisted entities.
> Teneo team envision eventually switching to annotations eventually? or
> at least, support them too?
> developed for it?
> rocks!
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo plan to support java5 annotations instead of EMF? [message #74564 is a reply to message #74546] Thu, 08 March 2007 20:54 Go to previous message
Thanks Martin,
this is all very interesting and i understand your point of view and im
glad to know more about the Teneo vision. In any case, teneo is really a
great project, its not for nothing we are migrating our
POJO/Hibernate/XDoclet model to EMF/Teneo/Hibernate. :)
As for annotations, I did create a feature request for EMF 3.0 to add
the possibility to support java5 annotations in the future. But of
course, this is just a generic feature and has a broad range of
applications (like the very useful attribute programming in .NET); i
fully understand why Teneo prefers to avoid EJB 3 specs to offer a more
flexibly product.
thanks!
Martin Taal wrote:
> Hi Jean-Denis,
> Teneo will not generate java 5 annotations in the source code. The
> source code generation is handled by native emf and not by Teneo and
> custom code generation templates to get this solved. The reason for
> this is that this is a great amount of work and would not necessarily
> personal opinion) I am not that much in favor of adding jpa
> annotations (with for example column/table names) in the java code. I
> jpa/ejb3 spec in a separate xml file). But I fully understand that
> Teneo currently also allows you to specify annotations in xml. This
> jpa/ejb3 standard.
> we will add support for generating ejb3/jpa xml files which follow the
> standard exactly. This jpa/ejb3 mapping file can then be edited (with
> afaics).
> model. With Teneo you only need to specify annotations to override
> still map it to the db (and generate a hibernate/jpox and later
> database but the model is mapped to the relational database. This
> allows support for dynamic emf. At runtime teneo resolves the model to
> gr. Martin
>> Hello,
>> about this:
>> if i understand correctly, will assist in mapping of EJB3 persistence
>> in code. From what I understand about EJB3 is that it uses java 5
>> Is there a particular reason for not using Java5 annotations? Does
>> the Teneo team envision eventually switching to annotations
>> eventually? or at least, support them too?
>> be developed for it?
>> rocks!
Re: Teneo plan to support java5 annotations instead of EMF? [message #603340 is a reply to message #74257] Thu, 08 March 2007 20:17 Go to previous message
Hi Jean-Denis,
gr. Martin
> Hello,
> this:
> developed for it?
> rocks!
The Netherlands
Re: Teneo plan to support java5 annotations instead of EMF? [message #603345 is a reply to message #74546] Thu, 08 March 2007 20:54 Go to previous message
Thanks Martin,
flexibly product.
thanks!
Martin Taal wrote:
> Hi Jean-Denis,
> jpa/ejb3 standard.
> afaics).
> gr. Martin
>> Hello,
>> about this:
>> rocks!
Previous Topic:[Teneo] Invalid subclass tag in hibernate mapping file .
Next Topic:EclipseCon 2007 - Teneo presentation and demo files
Current Time: Tue Jul 22 01:53:29 EDT 2025
Powered by FUDForum. Page generated in 0.04494 seconds
