Home » Archived » M2M (model-to-model transformation) » [ATL][newbie] Some problem in UML2 to UML2 transformation
[ATL][newbie] Some problem in UML2 to UML2 transformation [message #74240] Mon, 04 February 2008 10:41 Go to next message
Originally posted by: zappasan.gmail.com
Hi!
I want to execute a transformation that from a class stereotyped by
<<wsdl>> create one class for each wsdl element. For example if I have a
class named DatabaseManager stereotyped by <<wsdl>> I want in output all
the classes about wsdl language (definition, portType, ecc.). This not
properly a mapping but a creation of classes from zero. I have some
problems:
1. I have to Setup the type of some property and I've written this code:
type <- UML2!DataType.allInstancesFrom('UML2')->any(e | e.name = 'String')
But it has no effect at the uml output file. When I go to obeserve the
"type" feature of the property I have a blank field.
2. How Can I setup an association between two classes?
This what I've written
helper def: c1: UML2!Property = '';
rule createPT{
from
cs: UML2!Class (cs.hasStereotype('service::wsdl'))
to
ct: UML2!Class,
p0: UML2!Property(
name<-'name',
'String'),
default<-cs.name
a: UML2!Association
do{
ct.name<-'wsdl:PortType'+thisModule.counter.toString();
thisModule.counter <-thisModule.counter+1;
ct.ownedAttribute<-Set{p0};
a.name<-thisModule.c1.name+'To'+ct.name;
a.memberEnd<-Set{p0, thisModule.c1};
The helper caches a property defined in the creation of another class. I
can't think that this association set up works fine because in the
relatedElement feature I have blank.
Can you help-me please?
Thank you
Emanuele
Re: [ATL][newbie] Some problem in UML2 to UML2 transformation [message #79615 is a reply to message #74240] Sat, 19 April 2008 08:15 Go to previous message
Emanuele Hello,
Would like of knows how you resolved this problem? I'm with the same
problem.
You could send the file atl transformation?
What UML2 metamodel you used?
Grateful!
Previous Topic:[ATL] Problem with ATL rules
Next Topic:Composing Transformations
Current Time: Thu Nov 20 23:46:55 EST 2025
Powered by FUDForum. Page generated in 0.03756 seconds
