Home » Modeling » BPEL Designer » Map an External Model to BPEL Model like uiextensionmodel?
Map an External Model to BPEL Model like uiextensionmodel? [message #6688] Thu, 08 February 2007 16:51
Originally posted by: ahocking.roguewave.com
I would like to add metadata to various elements in the BPEL Model, create a
property page for that data and save the meta data in a separate file like
the .bpelex. There would end up being 3 files for a given BPEL, .bpel,
..bpelex, .bpelfoo.
I've looked through most of the UI code, looking at how it handles the
uiextensionmodel and the ExtensionMap. Adding Adapters to the
ModelListenerAdapter shouldn't be too difficult, but tapping into your
undo/redo framework would be tricky. Also, there is only one extensionMap
for a given editor. Anything stored there will be persisted to .bpelex. If
I manage my own FooExtensionMap, how can I listen for file load/save to
persist to a separate file? I'd rather not reproduce what you have already
implemented, but rather have the ability to add an ExtensionMap to some
collection of ExtensionMaps so that the existing code could handle the
command stack, persistence, etc. for (n) extension models.
Is this possible? Is there something I have missed that would provide this
extensibility?
Thank you,
- Arron Hocking
Previous Topic:Using BPEL model
Next Topic:where is BPEL Source code?
Current Time: Tue Nov 11 03:24:47 EST 2025
Powered by FUDForum. Page generated in 0.04420 seconds
