Home » Archived » Visual Editor (VE) » Lack of documentation?
Lack of documentation? [message #74049] Tue, 07 December 2004 13:36 Go to next message
Originally posted by: mward.harmonia.com
HellO!
I am currently in the process of looking into using some of VE's
functionality for a project I am working on, unfortunatly I cannot find
any documentation regarding development with VE. The main thing I am
trying to utilize is the given LayoutEditPolicies. This task would be
much simpler if there was an API or documentation for developers. Does
anybody know of any such resources?
THanks
Re: Lack of documentation? [message #74231 is a reply to message #74049] Tue, 07 December 2004 17:12 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Hi Matthew,
Currently there's no real developer documentation for the VE... up to
this point it's been pretty much considered all internal API. Opening
up the VE API and providing developer documentation is one of the major
goals of the next release - see the Project Plan for the 1.1 release
here:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/current-plan/vep-plan-1.1-draft.ht ml
That being said, other projects have sucessfully extended the VE already
- including the ULC Visual Editor and the AUIML VisualBuilder. The VE
developers of VE will be happy to help out with any specific questions
you have about the VE's functionality or code, either here on the
newsgroup or on the VE-dev mailing list.
Good luck!
- Jeff
Matthew Ward wrote:
> HellO! I am currently in the process of looking into using some of VE's
> THanks
Re: Lack of documentation? [message #603770 is a reply to message #74049] Tue, 07 December 2004 17:12 Go to previous message
Hi Matthew,
here:
Good luck!
- Jeff
> THanks
Previous Topic:Problems with SWT
Next Topic:Difference between Eclipse 3.0.0 and Eclipse 3.0.1
Current Time: Tue Nov 04 18:45:33 EST 2025
Powered by FUDForum. Page generated in 0.05632 seconds
