Home » Newcomers » Newcomers » Java workingset from a Simple project. What is the point!!!!!
Java workingset from a Simple project. What is the point!!!!! [message #73951] Sun, 05 June 2005 08:18 Go to next message
Hello
recently I created a simple project and imported a section of the
filesystem. Within that filesystem there was a number of Java source files.
As I was creating a working Set it Eclipse gave the option to choose a Java
Working Set.
However I don't quite understand why this option is avalible because when I
tried to use a Java menu option such as organise imports a message box
appears with the messsage "The resource is not on the build path of a Java
Project".
Is this pointless or is there a good reason why the Java Working Set option
is avalible when the projedct is a Simple project?
thanks
Re: Java workingset from a Simple project. What is the point!!!!! [message #74396 is a reply to message #73951] Mon, 06 June 2005 11:41 Go to previous messageGo to next message
"Martin Holmes" <martincanbe@hotmail.com> wrote in message
news:d7ut6n$tic$2@news.eclipse.org...
option
I guess you should file a big :-)
Re: Java workingset from a Simple project. What is the point!!!!! [message #74485 is a reply to message #73951] Mon, 06 June 2005 12:13 Go to previous message
Originally posted by: eclipse.rizzoweb.com
Martin Holmes wrote:
> Hello
> Working Set.
> Project".
I would guess that the reason is because Working Sets are somewhat
orthogonal to Projects. They can cross project boundaries and can
out-live Projects. Certainly a Working Set does not apply to just one
Project, so they allow you to create a Java working set whose contents
may include non-Java projects. Non-Java projects can contain .java files
(as you've done), which might be included in a Java working set even if
their project is not Java-aware.
HTH,
Eric
Previous Topic:How do I build a project?
Next Topic:Integrated UML designer/code generator for Eclipse?
Current Time: Thu Jul 17 19:35:14 EDT 2025
Powered by FUDForum. Page generated in 0.09466 seconds
