| Delete HelloWorld.class file, won't run again [message #73808] |
Sun, 05 June 2005 02:00  |
Originally posted by: diviner_chan.hotmail.com_
Hi all,
I tried to write a simple console application "HelloWorld" and
work well in a development cycle. Then I tried to delete the
HelloWorld.class to let Eclipse make it for me again, but
always failed. It gave me the error:
java.lang.NoClassDefFoundError: HelloWorld
Exception in thread "main"
(with a dialog -- "Could not find the main class. Program will exit")
How to solve it? Thank you very much.
Diviner.
| Re: Delete HelloWorld.class file, won't run again [message #74770 is a reply to message #74414] |
Tue, 07 June 2005 03:31   |
Originally posted by: divinerchan.gmail.com
Eric Rizzo,
I don't know do compile/re-compile in a separate operation. I do
it in Run->Run from context menu of Project in Package Explorer
or Run->Run Application then select particular project.
Diviner.
> Diviner wrote:
>> Hi all,
> After you deleted the .class file, how did you tell Eclipse to
> re-compile it for you? In a standard configuration, Eclipse will
> re-build the project (re-compile all Java source files) when you make a
> change to the source and save it, or if you select Project > Clean from
> the menu.
> HTH,
> Eric
| Re: Delete HelloWorld.class file, won't run again [message #74988 is a reply to message #74770] |
Tue, 07 June 2005 11:08   |
Originally posted by: eclipse.rizzoweb.com
Diviner wrote:
> Eric Rizzo,
If you deleted the .class file, you have to re-compile it. As I said
below, you can do that by either touching the source code and saving it,
or by choosing Project > Clean from the menu.
>> Diviner wrote:
>>> Hi all,
>> a change to the source and save it, or if you select Project > Clean
>> from the menu.
>> HTH,
>> Eric
| Re: Delete HelloWorld.class file, won't run again [message #74996 is a reply to message #74988] |
Tue, 07 June 2005 12:08  |
Eric Rizzo,
Yes, it is work for me. Thank you very much.
Diviner.
> Diviner wrote:
>> Eric Rizzo,
FUDForum. Page generated in 0.11826 seconds
