Home » Archived » BIRT » string concatenation in expression builder
string concatenation in expression builder [message #73780] Wed, 14 September 2005 05:31 Go to next message
I am trying to include a dynamically generated image in a report. I have
added the image and am struggling to dynamically build the URI for it
through the expression builder.
I would've thought that this
var url ="http://localhost/getImage?param=" + row["myparam"];
returns the url as a string with the parameter attached, but it doesn't.
What am I missing here? Are there any good sources of expression builder
examples, except for the help topics?
Jorg Heymans
Re: string concatenation in expression builder [message #74015 is a reply to message #73780] Wed, 14 September 2005 14:02 Go to previous messageGo to next message
Hi Jorg,
Any luck with this? What are you getting back as a value when you run?
Jorg Heymans wrote:
> Regards
> Jorg Heymans
Re: string concatenation in expression builder [message #74032 is a reply to message #74015] Wed, 14 September 2005 14:17 Go to previous messageGo to next message
Actually no, I gave up on this :-(
I tested with the simplest concat operation :
var url ="http://localhost/getImage?param=" + "staticvalue" ;
but when i click preview then it says it can't find the file "var
url="http....." , so it seems like its not evaluating the expression at all.
Are expressions supported at all for image URIs ? I didn't get the
impression from the docs that they're not.
Jorg
Re: string concatenation in expression builder [message #74074 is a reply to message #74032] Wed, 14 September 2005 03:22 Go to previous messageGo to next message
Jorg
I may be missing what you are asking, but
if I add an image and then using the expression builder I
type
"http://urltomypic" + picvariable
and then in the initialize method of the report I type
var picvariable = "testimage.jpg";
This works for me.
Am I missing something?
Jason Weathersby
BIRT PMC
"Jorg Heymans" <jh@domek.be> wrote in message
news:dg9pg8$aau$1@news.eclipse.org...
> all.
> Thanks
> Jorg
Re: string concatenation in expression builder [message #74348 is a reply to message #74074] Thu, 15 September 2005 04:12 Go to previous messageGo to next message
Jason Weathersby wrote:
> Jorg
> type
> This works for me.
How would you write this without using the initialize method ? I tried
exactly this by using the following expression as URI
"http://urltomypic" + "/testimage.jpg" , this should yield the same
results no ? It doesn't evaluate this expression somehow.
I was trying to use the results of a query as parameters in my URI
expression, but when that wasn't working i tried to get it to work
statically ie with the parameters precomputed. This is how i got to this
string concatenation problem...
Jorg
Re: string concatenation in expression builder [message #74399 is a reply to message #74348] Wed, 14 September 2005 22:34 Go to previous messageGo to next message
Jorg,
I tested your scenario on my system and it worked fine.
Can you cut the expression and post it?
Dont use
var url ="....
Just let the last line in the expression builder be
Jason Weathersby
BIRT PMC
news:dgbae7$56i$1@news.eclipse.org...
>> Jorg
>> type
>> This works for me.
> Jorg
Re: string concatenation in expression builder [message #75407 is a reply to message #74399] Mon, 19 September 2005 04:06 Go to previous message
> Jorg,
> Dont use
> var url ="....
Sorry for the delay.
I have isolated a testcase showing my problem. If the attachment does
not come through, get it from www.domek.be/imagetest.rptdesign
Jorg
Previous Topic:How to generate Html report using birt
Next Topic:How do I connect BIRT with Sybase
Current Time: Mon Nov 10 13:13:04 EST 2025
Powered by FUDForum. Page generated in 0.04859 seconds
