Home » Language IDEs » PHP Development Tools (PDT) » PDT (1.0.3) with X-Debug (2.0): Variables view
PDT (1.0.3) with X-Debug (2.0): Variables view [message #73609] Tue, 17 June 2008 06:10 Go to next message
Hi all,
i have a question about the variables view but i do not know if this is
the right place for it
Since i changed from Zend debugger to X-Debug (which has a lot greater
performance and stability) the variables shown in the view are clustered
into 30entries per Array/Object. Also the entries are not sorted
alphabetical.
Now i have got an application were some Objects/Array consits of 500++
elements and it takes a lot of time finding a special one.
Are there any options to configure? I only found php.ini lines for maximal
children which not affects remote debugging.
Somebody any idea?
Greetings and thx for help
Nikolai Essel
Re: PDT (1.0.3) with X-Debug (2.0): Variables view [message #73628 is a reply to message #73609] Tue, 17 June 2008 07:58 Go to previous messageGo to next message
Nothing available currently that can help. Array/Object elements are presented in order that xdebug
sends them over. I recommend you raise a bugzilla enhancement describing the scenario and what kind
of facilities you would like to see which would help in your debugging, eg sorting same level keys,
a search facility, creating a tree structure based on the first character of the key rather than
just grouping by a count etc.
https://bugs.eclipse.org/bugs
Dave Kelsey
Nikolai Essel wrote:
> Hi all,
> alphabetical.
> maximal children which not affects remote debugging.
> Somebody any idea?
> Nikolai Essel
Re: PDT (1.0.3) with X-Debug (2.0): Variables view [message #73716 is a reply to message #73628] Fri, 20 June 2008 22:00 Go to previous messageGo to next message
How does one uinstall the zend debugger. I am following Dave Kelseys pdf
for using xdebug with pdt(which I think is out of date btw. Some of the
screen shotts in the pdf do not correspond with eclipese v3.3.2 Europa but
that is a seperate post)but I think that i have to uninstall the zend
debugger to keep it from conflicting within pdt with xdebug. I have tried
deleting everything with zend in the plugins directory but those choices
still show up in the Windows-->Preferences--->PHP--->Debug--->Installed
Debuggers Screen.
Re: PDT (1.0.3) with X-Debug (2.0): Variables view [message #73769 is a reply to message #73716] Sat, 21 June 2008 11:14 Go to previous message
Originally posted by: dkel50.hotnospmail.com
The document is a bit out of date. I must get around to creating a new
version for PDT 1.0.3, but most of it is still relevant.
You don't need to uninstall the zend debugger. If you get PDT 1.0.3 then
you will have both the zend debugger support and xdebug client support
already built in and co-existing. Zend listen on port 10,000 by default
and xdebug client listens on port 9,000.
Dave Kelsey
> but that is a seperate post)but I think that i have to uninstall the
> zend debugger to keep it from conflicting within pdt with xdebug. I have
> tried deleting everything with zend in the plugins directory but those
> choices still show up in the
> Windows-->Preferences--->PHP--->Debug--->Installed Debuggers Screen.
Previous Topic:Problems after upgrade
Next Topic:Re: Eclipse Not Really Saving File Changes
Current Time: Wed Nov 19 12:39:38 EST 2025
Powered by FUDForum. Page generated in 0.10201 seconds
