| no swt-win32-2132 when trying to compile Simpel charts example [message #73608] |
Mon, 31 March 2003 17:06  |
Originally posted by: dev.abgraph.com
I am new to Java and trying to build the simplest of all gef examples:
http://eclipsewiki.swiki.net/50#simpleCharts
I am following the instructions only replacing the
import com.ibm.etools.draw2d.*;
import com.ibm.etools.draw2d.geometry.*;
to:
import org.eclipse.draw2d.*;
import org.eclipse.draw2d.geometry.*;
I am getting the following Console output when trying to run the sample:
java.lang.UnsatisfiedLinkError: no swt-win32-2132 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1403)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:832)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 4)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:42)
at org.eclipse.swt.widgets.Display.internal_new_GC(Display.java :1230)
at org.eclipse.swt.graphics.Device.init(Device.java:543)
at org.eclipse.swt.widgets.Display.init(Display.java:1249)
at org.eclipse.swt.graphics.Device.<init>(Device.java:92)
at org.eclipse.swt.widgets.Display.<init>(Display.java:287)
at org.eclipse.swt.widgets.Display.<init>(Display.java:283)
at ChartDemo.main(ChartDemo.java:34)
Exception in thread "main"
Anyboy any clue as to what may be wrong?
I am using Version: 2.1.0 Build id: 200303071024 on j2sdk1.4.1_02
Any suggestions or help more than welcome!
Gert
FUDForum. Page generated in 0.03850 seconds
