Home » Newcomers » Newcomers » new Color Class problem
new Color Class problem [message #73607] Sat, 04 June 2005 11:06 Go to next message
Originally posted by: farocena.gmail.com
when I want to set the background color of a label:
label.setBackground(new Color(display,200,111,50));
I get this compilation error:
Exception in thread "main" java.lang.Error: Unresolved compilation
problem:
Color cannot be resolved to a type
at SWTHallo.main(SWTHallo.java:31)
Any clues?
Thanks in advance,
Fabián
Re: new Color Class problem [message #74787 is a reply to message #73607] Tue, 07 June 2005 03:32 Go to previous message
> problem: Color cannot be resolved to a type
> Any clues?
> Thanks in advance,
> Fabián
I hope you have imported this...
import java.awt.Color;
If so, check the properties of your project: Java Build Path - Libraries
should contain a library with java.awt.Color.class (usually, it is in
rt.jar inside JRE System Library).
Previous Topic:Problem installing CDT
Next Topic:org.eclipse.core.commands plugin
Current Time: Fri Nov 07 03:09:48 EST 2025
Powered by FUDForum. Page generated in 0.30056 seconds
