Home » Archived » BIRT » __format=pdf or html doesn't work
__format=pdf or html doesn't work [message #73604] Tue, 13 September 2005 13:10 Go to next message
Originally posted by: chaohua.wang.premierata.com
Hi Folks,
I am owrking on birt-viewer.
http://localhost:8888/birt-viewer/run?__report=report%5Cmyre port.rptdesign
which shows report correctly.
But I add __format=pdf behind this url
http://localhost:8888/birtv-viewer/run?__report=report%5Cmyr eport.rptdesign__format=pdf
I got this error in the browser.
The design file C:\Tomcat
5.5\webapps\pdsstudio\report\myreport.rptdesign__format=pdf can not be
found.
Please tell me what is wrong. Thank you.
chwang
Re: __format=pdf or html doesn't work [message #73622 is a reply to message #73604] Tue, 13 September 2005 14:07 Go to previous message
Hi Chwang,
You should include an ampersand (&) before the parameter name, so the
application recognizes this as a parameter.
This should work:
http://localhost:8888/birtv-viewer/run?__report=report%5Cmyr eport.rptdesign&__format=pdf
Bart
On Tue, 13 Sep 2005 11:10:53 -0600, chaohua wrote:
> Hi Folks,
> found.
> chwang
Previous Topic:automatically set the Driver URL
Next Topic:General scripting
Current Time: Wed Jul 16 10:07:44 EDT 2025
Powered by FUDForum. Page generated in 0.03271 seconds
