Home » Archived » BIRT » Nested Query as Parameter
Nested Query as Parameter [message #73548] Tue, 13 September 2005 11:09 Go to next message
Can I use a nested query as a parameter in BIRT?
I created a Data Set with the following SQL Query:
SELECT FirstName
FROM Users
WHERE (Users.Firstname IN (?))
Then I set param1 to be a String with a default value of:
"SELECT Users.FirstName FROM Users WHERE Users.FirstName like 'm%'"
I know this is a silly query when you add the parameter in place of the ?,
but this is just a simplified example of the functionality I need. I would
expect this to return all users who's first name starts with the letter 'm',
but I get no results when I click Preview Results or run some report with
this dataset.
Can I use parameters in this way? Am I just misusing my quotation marks or
something like that?
Thanks for the info!
--Floor
Re: Nested Query as Parameter [message #73978 is a reply to message #73548] Wed, 14 September 2005 01:39 Go to previous messageGo to next message
Floor,
If you build a query say
select * from customers
Set no dataset parameters, but create a report parameter
like
ParamSubSelect type String and then set its default value to something like
"(Select customerNumber from customers where customers.customerName like
'%Z%')"
Then edit the beforeOpen method of the dataset and set queryText to the
following:
queryText ="select * from customers where (Customers.customerNumber IN " +
params["ParamSubSelect"] + ")";
This should do what you are looking for.
One caveat is that you will get exception in the designer when you first
open the report, but the report will run. I am looking into why the error
occurs.
Jason Weathersby
BIRT PMC
"floor" <floorflux@hotmail.com> wrote in message
news:dg6q4g$sio$1@news.eclipse.org...
> SELECT FirstName
> FROM Users
> would expect this to return all users who's first name starts with the
> letter 'm', but I get no results when I click Preview Results or run some
> report with this dataset.
> or something like that?
> --Floor
Re: Nested Query as Parameter [message #74620 is a reply to message #73978] Thu, 15 September 2005 16:12 Go to previous message
That works great! Thanks a ton!
--Floor
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dg9net$7br$1@news.eclipse.org...
> Floor,
> like
> like
> '%Z%')"
> following:
> occurs.
> Jason Weathersby
> BIRT PMC
>> SELECT FirstName
>> FROM Users
>> ?, but this is just a simplified example of the functionality I need. I
>> some report with this dataset.
>> --Floor
Previous Topic:How to get the resultset from dataset?
Next Topic:TextDataHandle ????
Current Time: Tue Jul 22 01:38:55 EDT 2025
Powered by FUDForum. Page generated in 0.04486 seconds
