Home » Modeling » GMF (Graphical Modeling Framework) » Code generation errors
Code generation errors [message #72974] Wed, 01 November 2006 14:11 Go to next message
Originally posted by: jdlewis.ncsu.edu
I am completely new to GMF and I went through the first tutorial using GMF
1.0.1. After I finished generating the code I noticed that there where 19
syntax errors in the code. At first I though I did something wrong but as
a syntax error in auto generated code I am not sure. These errors where
in some assert statements. Thing like a ':' when the compiler is
expecting a '|'. At least that is what the compiler said. Also when I
actually test the tutorial's plug in I get nothing. I mean I create the
new project, add the diagram, but when the diagram loads it is just a grey
screen. There are no tool bars no white layout screen nothing. Any ideas
on these two problems?
Re: Code generation errors [message #73377 is a reply to message #72974] Thu, 02 November 2006 09:55 Go to previous message
Hi Jonathan,
If there are compile errors in the generated code do you not get errors in
the log that plug-ins could not load due to these errors?
Are you sure you set the compiler settings to 1.4? Instructions on how to do
this are at the start of the tutorial.
Cheers...
Anthony
"Jonathan D. Lewis" <jdlewis@ncsu.edu> wrote in message
news:623de4d58545cb71523ab08f7e109449$1@www.eclipse.org...
>a syntax error in auto generated code I am not sure. These errors where in
>some assert statements. Thing like a ':' when the compiler is expecting a
>'|'. At least that is what the compiler said. Also when I actually test
>the tutorial's plug in I get nothing. I mean I create the new project, add
>the diagram, but when the diagram loads it is just a grey screen. There
>are no tool bars no white layout screen nothing. Any ideas on these two
>problems?
Previous Topic:[Announce] Extending your DSM by leveraging the GMF Runtime
Next Topic:Simple question
Current Time: Tue Oct 28 22:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.04618 seconds
