Home » Archived » Higgins » shangrila.parityinc.net:8888
shangrila.parityinc.net:8888 [message #6542] Wed, 12 March 2008 12:11 Go to next message
i'm trying to install the Higgins STS application. In the "Deploy Token
Service"
instructions there are references to OpenLDAP schema, LDIF and config files
to be available on the shangrila.parityinc.net:8888 web site.
It seems that server is not active (we have tried for two days). Where I can
find the right place??. TIA, ciao
Cristoforo Seccia
TXT e-solution SPA
Re: shangrila.parityinc.net:8888 [message #8120 is a reply to message #6542] Wed, 18 June 2008 03:46 Go to previous messageGo to next message
Originally posted by: vincent.lojou.atosorigin.com
I'm going to work on the FC² project for Atos Wordline and I want to
familiarize myself with the Higgins STS_IdP application.
I have the same problem described before, the link for
"shangrila.parityinc.net:8888" is broken.
Where can I found the necessary files for the configuration of OpenLDAP ?
Thx
Vincent Lojou
Atos Worldline France
Re: shangrila.parityinc.net:8888 [message #8149 is a reply to message #8120] Fri, 20 June 2008 21:37 Go to previous message
Hi Vincent - thanks to some Higgins project engineers (Markus and Stas) we
have tracked down broken links/missing files off
http://wiki.eclipse.org/Deploy_Token_Service page. We have Sergey Lyakhov
working on fixing the links with the missing files. We should have this
fixed by Monday. We hope these will resolve the issues with STS_IdP.
regards...Brian
Re: shangrila.parityinc.net:8888 [message #562834 is a reply to message #6542] Wed, 18 June 2008 03:46 Go to previous message
Thx
Vincent Lojou
Re: shangrila.parityinc.net:8888 [message #562858 is a reply to message #8120] Fri, 20 June 2008 21:37 Go to previous message
regards...Brian
Previous Topic:Introductory Documents
Next Topic:Higgins Status
Current Time: Fri Nov 21 09:09:33 EST 2025
Powered by FUDForum. Page generated in 0.04945 seconds
