Home » Language IDEs » C / C++ IDE (CDT) » help - (Exec error:Launching failed)
help - (Exec error:Launching failed) [message #72746] Wed, 04 June 2003 02:17 Go to next message
I am new to Eclipse CDT. I have successfully use MinGW to compile my
hello.c program but unable to do it inside Eclipse. Everything I try to
do a built I got the following message on the console.
Build Error
I suspect it couldn't find 'gcc' but I could find anything in the
preferences or project properties to specify where 'gcc' is. May be I am
in the wrong track all together. Any help is appreciated.
Kar
Re: help - (Exec error:Launching failed) [message #72757 is a reply to message #72746] Wed, 04 June 2003 09:02 Go to previous messageGo to next message
> Build Error
> Kar
Add MinGW\bin to your PATH, if you use MSYS add this to the PATH too.
If you use MSYS check, the PATH.
If you just use MinGW without MSYS, check if you have an make.exe in your
binary-path, otherwise, copy mingw32-make.exe to make.exe or, change the
default build command to mingw32-make and add the following line to your
Makefiles:
MAKE = mingw32-make
and change all occurences of make with $(MAKE)
Re: help - (Exec error:Launching failed) - Thx [message #72767 is a reply to message #72757] Wed, 04 June 2003 18:26 Go to previous message
> > Build Error
> > Kar
> Makefiles:
> MAKE = mingw32-make
Thx. It works now :)
Previous Topic:Eclipse CDT on HPUX 11.0
Next Topic:Problems with build configurations
Current Time: Sun Nov 16 23:33:16 EST 2025
Powered by FUDForum. Page generated in 0.10824 seconds
