Home » Eclipse Projects » Equinox » How can I start the Equinox OSGi frame with Java 2 Security?Does it work?
How can I start the Equinox OSGi frame with Java 2 Security?Does it work? [message #72728] Thu, 31 August 2006 05:18 Go to next message
hi,folks
I know I can start the Equinox framework with Security using below
command;
java -jar org.eclipse.osgi_3.1.0.jar -console
But now I want to learn the Security of the Equinox, so I start the
framework by below command:
java -Djava.security.manager -Djava.security.policy=c:\osgi\java.policy
-jar org.eclipse.osgi_3.2.0.v20060328.jar -console
I assign the AllPermissions for the org.eclipse.osgi_3.2.0.v20060328.jar
file in the java.policy file. Dose this right?
If I want to install a Bundle to this framework which register a server to
the framework, need I set the ServicePermission(Register) for that Bundle
When I do this, it looks like the OSGi Security doesn't take effect. Can
you help me? This problem really bother me a lots.
Best Regards!
Thanks!
yangxfei@cn.ibm.com
Re: How can I start the Equinox OSGi frame with Java 2 Security?Does it work? [message #72742 is a reply to message #72728] Thu, 31 August 2006 10:27 Go to previous message
BTW, Where can I find more documents about the Security of Equinox OSGi
framework? Is there any example?
Thanks very much
Previous Topic:ServiceTracker
Next Topic:security policy for equinox framework
Current Time: Wed Oct 22 06:46:41 EDT 2025
Powered by FUDForum. Page generated in 0.26616 seconds
