Home » Eclipse Projects » Eclipse Platform » problem running an ant script in elipse.
problem running an ant script in elipse. [message #72240] Thu, 12 June 2003 12:02 Go to next message
Originally posted by: pchaudhari.empactcorporation.com
I have eclipse 2.1 on my win 2k machine. I have created a small application,
and have a small build file. When i click on run ant..., the ant dialog box
for the build file of the project comes up with the target tab selected. The
icon has a an x mark in a red circle. There are no entries in the Check
targets to execute. and at the top under the Modify attributes and launch
there is an error as follows.
(class: org/apache/xerces/parsers/IntegratedParserConfiguration, method:
configurePipeline signature:()V) Incompatible type for getting or setting
field
This build file runs from the command prompt. I am guessing it's probably a
class path issue, i just can't figure out what. can someone please help me
out on this?
thank you.
Poorav
Re: problem running an ant script in elipse. [message #72257 is a reply to message #72240] Thu, 12 June 2003 12:16 Go to previous message
You have included the Xerces JARs in the Ant runtime classpath or have set
an ANT_HOME that directly or indirectly includes these JARs
If you have added the Xerces JARs, remove them. Eclipse's Ant integration
needs to use the JARs provided in the Xerces plugin.
See the Eclipse readme for more details.
If you have set ANT_HOME see the README bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=34151
HTH
Darins
"Poorav" <pchaudhari@empactcorporation.com> wrote in message
news:bca8d4$afg$1@rogue.oti.com...
application,
box
The
> field
a
> out on this?
> thank you.
> Poorav
Previous Topic:ANT build and running in separate JVM.
Next Topic:Ant & Eclipse javac problem
Current Time: Mon Nov 17 05:02:48 EST 2025
Powered by FUDForum. Page generated in 0.03365 seconds
