Home » Newcomers » Newcomers » "target release conflicts with default source release"
"target release conflicts with default source release" [message #72158] Wed, 01 June 2005 14:37
Originally posted by: wei725.lycos.com
Using the M3.1 version, I use the Java 1.5 for development. Now, I need to
have a deployment build for Java 1.4. After a few of code changes and set
the target to 1.4 in the ant.xml, I also change to the 1.4 in the Java
compiler setting of the properties for the project. I run into this error
message when I try to compile the project with ant:
target release 1.4 conflicts with default source release 1.5
I can't find any place else that I can change the Java version setting.
What I am missing here?
Thanks very much in advance for your helps.
w.
Previous Topic:Package Explorer: colour special packages
Next Topic:getting started on Mac?
Current Time: Mon Jul 21 21:11:30 EDT 2025
Powered by FUDForum. Page generated in 0.54251 seconds
