Home » Eclipse Projects » Remote Application Platform (RAP) » Eclipse help system problem
Eclipse help system problem [message #72103] Tue, 29 January 2008 14:39 Go to next message
Originally posted by: jose.c.pacheco.criticalsoftware.com
Hi all,
I'm trying to use the eclipse help system with rap, the problem is that
rap registers resources under "/" and eclipse help system also, so the
second bundle can not register the resources because the alias "/" is
already taken.
Can someone help me on this please? Is there some way of making eclipse
help system work with rap?
Thanks in advance,
José Pacheco.
Re: Eclipse help system problem [message #72666 is a reply to message #72103] Fri, 01 February 2008 08:08 Go to previous message
Originally posted by: fappel.innoopract.com
from your question I assume that you are trying to install two webapps, one
for the helpsystem and your actual application written in RAP. This isn't
necessary since you can integrate the eclipse helpsystem within the RAP
application. There are several newsgroup posts about this - just search for
'org.eclipse.help'.
Ciao
Frank
"Jos
Previous Topic:Context menus for TableHeaders
Next Topic:ServletContextListener
Current Time: Fri Jul 18 08:20:28 EDT 2025
Powered by FUDForum. Page generated in 0.09372 seconds
