Home » Archived » BIRT » I have install JDBC for Oracle but....!!!
I have install JDBC for Oracle but....!!! [message #72060] Mon, 05 September 2005 10:32 Go to next message
Originally posted by: cesar.flores.ax.pirelli.com
Hi good guys.
I have install JDBC for Oracle but....!!! I can't connect to the DB. There
two drivers:
- oracle.jdbc.OracleDriver (v1.0)
- oracle.jdbc.driver.OracleDriver (v1.0)
Which one do I use?
And is this correct? --
DATABASE URL : jdbc:oracle:thin:@GRTIR:1534:GRTIR
or tell me what to do!! ;-(
THANKS in advance....GRAZIE MILLE!!!
Re: I have install JDBC for Oracle but....!!! [message #72139 is a reply to message #72060] Mon, 05 September 2005 18:15 Go to previous messageGo to next message
this and get last jdbc jar from oracle
> Which one do I use?
jdbc:oracle:thin:@localhost:1521:orcl
it can be 1534 if you set sqlnet with 1534 (this is only port and default is
1521)
@GRTIR - this is server name, try with @localhost
last GRTR (after 1534) is database name (I think that default is orcl or
ORCL - I change this always)
Thanks....Grazie!.... also try... [message #72224 is a reply to message #72139] Tue, 06 September 2005 04:46 Go to previous message
>> Which one do I use?
> 1521)
Thanks again!!
Instead the localhost name, I've tried to insert the IP address. And It
worked, with the localhost name it didn't..?!?!?! maybe, there's some
problem with my computer settings.... It happens sometimes. Anyway, If
someone have this problem, it is a good idea to try with the IP address.
Ex:
- jdbc:oracle:thin:@151.10.12.123:1521:orcl
- 1521 is the port connection, so write your port connection
- and orcl is the name of the database.
In this case I've solve the problem. Thanks anyway snpe.
Previous Topic:Binding a Data Set Parameter to Report Parameter Not Working
Next Topic:Choosing a 'Letter' report template
Current Time: Fri Jul 18 22:46:45 EDT 2025
Powered by FUDForum. Page generated in 0.03917 seconds
