Home » Archived » Test and Performance Tools Platform (TPTP) » Error into Sample Birt Report
Error into Sample Birt Report [message #72027] Mon, 29 May 2006 02:47 Go to next message
Originally posted by: s.claes.gfdi.be
Hello everebody,
I'd like testing the eaxmaple describe into page
http://www.eclipse.org/birt/phoenix/deploy/designEngineAPI.p hp and I have
a problem in line :
ReportDesignHandle design = sessionHandle.createDesign();
Error message
29-mai-2006 8:40:59 org.eclipse.birt.report.model.metadata.ExtensionLoader
logExtenstionException
GRAVE: Message:The extension point
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
What can I do for resolving this problem ?
In Advance thank you.
Stéphane
Re: Error into Sample Birt Report [message #72116 is a reply to message #72027] Mon, 29 May 2006 08:28 Go to previous message
Thank a lot but this problem is solved.
Previous Topic:Output format error
Next Topic:Slow profiling of Java application
Current Time: Sat Nov 15 07:38:51 EST 2025
Powered by FUDForum. Page generated in 0.03064 seconds
