Home » Language IDEs » AspectJ » ClassNotFoundException
ClassNotFoundException [message #71641] Fri, 06 June 2008 20:19
I created a very basic test case that calls one of our methods. I do not
have any aspects. If I execute it with AspectJ enabled on the project, I
get the stacktrace below. If I turn off AspectJ Capability then it runs
just fine. I looked in the output directory and the class does exist.
There are some compile errors in the project but that shouldn't affect
running the code because it works when AspectJ is turned off.
Any ideas how to fix this? Thanks.
Exception in thread "main" java.lang.NoClassDefFoundError: my.DepClass
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$000(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:289 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at MyClass.main(ModelChangeTest.java:23)
Caused by: java.lang.ClassNotFoundException: my.DepClass
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
... 13 more
Previous Topic:Forcing incremental build
Next Topic:ClassNotFoundException
Current Time: Sat Aug 30 21:38:23 EDT 2025
Powered by FUDForum. Page generated in 0.03274 seconds
