Home » Eclipse Projects » GEF » Palette alignment
Palette alignment [message #71565] Wed, 19 March 2003 20:04 Go to next message
Originally posted by: jayuen.alumni.uwaterloo.ca
Hi:
I'm using the GEF drop from Feb. 13, 2003. I was wondering if it is
possible to place the palette back on the left side of the editor rather
than the right side.
Jason
Re: Palette alignment [message #71608 is a reply to message #71565] Wed, 19 March 2003 23:20 Go to previous messageGo to next message
This is not possible for 2.1. We don't expect commercial quality Editors to
subclass GraphicalEditor. It exists to give you a quick starting point. But
based on history, at least 8 editors in IBM's Websphere tools use GEF, and
none of them inherits from GraphicalEditor.
We have made a conscious effort to have very little requirements on the
EditorPart. This allows applications to use GEF almost anywhere, including
multi-page editors and/or composite editors. I realize it would be nice to
be able to drag the Palette from the right to left side, but this is not
really GEF-specific function. For 2.2 we will work with the workbench team
to make the palette a View, or to make the Editor capable of hosting
view-like panels.
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:b5b430$hj8$1@rogue.oti.com...
> Hi:
> Jason
Re: Palette alignment [message #71837 is a reply to message #71608] Thu, 20 March 2003 13:40 Go to previous messageGo to next message
Thanks for the heads up Randy.
I'm actually just experimenting with the GraphicalEditor so I wanted to play
around with the layouts. I'm wondering if you could point me to the class
or method in the GEF source that sets up the palette to appear on the right
hand side. I figure that this shouldn't involve a major code change since
it used to be on the left in the older GEF drops. Or maybe not?
Thanks in advance,
Jason
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b5bfia$njj$1@rogue.oti.com...
to
But
team
> view-like panels.
> > Hi:
> > Thanks,
> > Jason
Re: Palette alignment [message #71856 is a reply to message #71837] Thu, 20 March 2003 15:13 Go to previous messageGo to next message
It seems like I can move the palette back to the left by simply switching
the order with which the GraphicalViewer and PaletteViewer are added to the
Splitter in the GraphicalEditorWithPalette:createPartControl.
thanks anyway,
Jason
news:b5d1t7$vg6$1@rogue.oti.com...
play
right
> Thanks in advance,
> Jason
> to
> But
and
including
to
> team
> > view-like panels.
> > > Hi:
rather
> > > Thanks,
> > > Jason
Re: Palette alignment [message #84499 is a reply to message #71608] Thu, 19 June 2003 18:07 Go to previous messageGo to next message
Should I assume then that the intended starting point for a commercial
quality editor which uses GEF is to simply subclass EditorPart?
And is it possible to concisely state (for a GEF newbie) why it is
better to start out by subclassing EditorPart as opposed to
GraphicalEditor (i.e. does something in GraphicalEditor not scale, etc)?
(Or is it perhaps merely historical accident and not some limitation of
GraphicalEditor that none of those Websphere tools you mentioned inherit
from GraphicalEditor--maybe they were started before GraphicalEditor
existed, perhaps?)
> view-like panels.
Since this was written a couple months ago, has there been any decision
on whether the palette is indeed going to become a view for 2.2? And if
so, is there any estimate on which of the 2.2 release milestones this
would be slated for?
Also (another newbie question--I apologize) is there any way to wrap the
2.1 palette in a view? (I would like the palette to go in a tab where
the Navigator is, for example, so I was hoping to make a view and
somehow put the palette in it. But I haven't read enough of the code
yet to know if this is possible, or how I would access the palette to
add it...)
Thanks in advance,
Peter Armstrong
Re: Palette alignment [message #84510 is a reply to message #84499] Thu, 19 June 2003 20:36 Go to previous message
"Peter Armstrong" <peterarmstrong@shaw.ca> wrote in message
news:bctcbb$lnt$1@rogue.oti.com...
to
But
and
These is lot's of crap that you have to do to be a well behaved editor. We
don't do any of it for you. You must respond to your input being renamed,
deleted, or moved. You must respond to different versions being loaded and
replacing the current contents. You must support validate-edit, for
pessimistic team environments.
Also, there is lots of stuff we do that maybe you don't want to do. For
example, Action management, or synchronizing the selection between the
outline and editor.
Also, you might want to inherit from MultiPageEditor, or write your own
multipage implementation, or maybe you want a split pane editor. Therefore,
we try to make sure that the interesting stuff in GEF is not burried in our
editor implementation.
If there is interesting code in our editor, maybe it can be factored out?
> existed, perhaps?)
including
to
team
> > view-like panels.
> add it...)
> Thanks in advance,
> Peter Armstrong
Previous Topic:Scrolling enhancement
Next Topic:ClassNotFoundException though jar file is included.
Current Time: Sun Aug 31 12:43:32 EDT 2025
Powered by FUDForum. Page generated in 0.08171 seconds
