Home » Modeling » M2T (model-to-text transformation) » Re: JET Null Pointer Exception & XPath Axes
Re: JET Null Pointer Exception & XPath Axes [message #6385] Wed, 21 March 2007 10:56 Go to next message
Toby:
In the future, please post messages to eclipse.modeling.m2t - I've cross
posted this response.
Please submit a bugzilla for the NPE:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org&qa_contact=
As for the supported axes, here is the current list:
attribute:: and the @ abbreviation
child:: and its abbreviated form
descendantOrSelf:: and the // abbreviation
parent:: and its .. abbreviation
self:: and its . abbreviation
If you need more, please submit an bugzilla enhancement.
Thanks for you interest,
Paul
"Toby Myers" <Toby.Myers@student.gu.edu.au> wrote in message
news:etn981$pa2$1@utils.eclipse.org...
> Hello All,
> I have just started using JET and I am having a problem with the default
> files from the EMFT JET Transformation Project. When I run the files I
> receive the error:
> templates/dump.jet(2,1): <c:dump entities="true" format="true"
> select="/*">
> Error: Error executing tag handler: java.lang.NullPointerException
> Does anyone know why this is happening?
> Also I read an old post about JET and XPath expressions that said not all
> the XPath axes are supported. Have any more XPath expressions been added
> since then, especially //. If not, can anyone suggest a good workaround?
> Cheers,
> Toby
Re: JET Null Pointer Exception & XPath Axes [message #6460 is a reply to message #6385] Wed, 21 March 2007 20:32 Go to previous messageGo to next message
Hi Paul,
I submitted the bug. In regards to the descendantOrSelf (//) I tried it
out with the "Create more -- better -- code in Eclipse with JET"
tutorial
( http://www-128.ibm.com/developerworks/opensource/library/os- ecl-jet/).
When I run the email.jet example (Example:Write code that does stuff)
everything works okay and I get the Chris.txt and Nick.txt. But if I
change the main.jet from:
<c:iterate select="/app/email" var="currEmail" >
<ws:file template="templates/email.jet"
path=" {$org.eclipse.jet.resource.project.name}/{$currEmail/@to}.tx t " />
</c:iterate>
to:
<c:iterate select="//email" var="currEmail" >
</c:iterate>
once again I get the NullPointerException:
templates/main.jet(1,1): <c:iterate var="currEmail" select="//email">
Errors occurred during execution
Any ideas? Have I done something wrong because I assume it would have
been discovered earlier or is it in fact a bug?
Toby
Paul Elder wrote:
> Toby:
> Paul
>> Hello All,
>> receive the error:
>> select="/*">
>> Cheers,
>> Toby
Re: JET Null Pointer Exception & XPath Axes [message #6498 is a reply to message #6460] Thu, 22 March 2007 08:53 Go to previous messageGo to next message
Toby:
Of course, it works on my machine :-( I have tested in in Eclipse 3.2.2/EMF
2.2.2/JET 0.7.2, and with somewhat stale versions of Eclipse 3.3 and EMF
2.3.
Also, take a look in the Error log - you should find a stack trace.
I'll continue to investigate.
Paul
Two question
news:etsis0$noi$1@utils.eclipse.org...
> Hi Paul,
> ... if I change the main.jet from:
> </c:iterate>
> to:
> </c:iterate>
Re: JET Null Pointer Exception & XPath Axes [message #9770 is a reply to message #6498] Sun, 01 April 2007 20:45 Go to previous message
Paul:
The setup causing problems was Eclipse 3.2.1/EMF 2.2.2/JET 0.7.1 running
on Ubuntu Linux.
I have since changed versions to Eclipse 3.2.2/EMF 2.2.2/JET 0.7.2 and
everything is working as it should.
Thanks for your help.
Toby
Paul Elder wrote:
> Toby:
> 2.3.
> Paul
> Two question
>> Hi Paul,
>> </c:iterate>
>> to:
>> </c:iterate>
Previous Topic:Error executin tag handler
Next Topic:How to get setVariable value back
Current Time: Thu Nov 20 20:24:45 EST 2025
Powered by FUDForum. Page generated in 0.03766 seconds
