Home » Archived » Test and Performance Tools Platform (TPTP) » Could not initialize class org.eclipse.hyades.models.hierarchy.HierarchyPackage
Could not initialize class org.eclipse.hyades.models.hierarchy.HierarchyPackage [message #71446] Sun, 21 May 2006 12:17
After installing TPTP 4.2 I am getting the following message when I try to
profile and application:
I looked around and didn't find much. As the attaced trace shows, I was
used Java 1.6 and found references to possible issues, so I went back to
1.5.0_06 and got the same behavior, only with a blank error message.
As anyone seen this before or can point me in the right direction.
Thanks for the help.
Alain
!ENTRY org.eclipse.osgi 4 0 2006-05-21 10:24:16.774
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.hyades.statistical.ui (467).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.hyades.statistical.ui.UiPlugin for bundle
org.eclipse.hyades.statistical.ui is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:49)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:238)
org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableEx tension(EarlyStartupRunnable.java:117)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1759 )
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Caused by: java.lang.NoSuchMethodError:
org.eclipse.emf.ecore.EPackage$Registry.getEFactory(Ljava/la ng/String;)Lorg/eclipse/emf/ecore/EFactory;
org.eclipse.hyades.models.hierarchy.impl.HierarchyFactoryImp l.init(HierarchyFactoryImpl.java:65)
org.eclipse.hyades.models.hierarchy.HierarchyFactory.<clinit >(HierarchyFactory.java:37)
org.eclipse.hyades.models.hierarchy.impl.HierarchyPackageImp l. <init>(HierarchyPackageImpl.java:262)
org.eclipse.hyades.models.hierarchy.impl.HierarchyPackageImp l.init(HierarchyPackageImpl.java:301)
org.eclipse.hyades.models.hierarchy.HierarchyPackage.<clinit >(HierarchyPackage.java:77)
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unkn own Source)
at sun.reflect.ReflectionFactory.newFieldAccessor(Unknown Source)
at java.lang.reflect.Field.acquireFieldAccessor(Unknown Source)
at java.lang.reflect.Field.getFieldAccessor(Unknown Source)
at java.lang.reflect.Field.get(Unknown Source)
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:167)
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:107)
org.eclipse.hyades.models.hierarchy.impl.HierarchyPackageImp l.init(HierarchyPackageImpl.java:299)
org.eclipse.hyades.model.statistical.impl.StatisticalPackage Impl.init(StatisticalPackageImpl.java:222)
at org.eclipse.hyades.statistical.ui.UiPlugin.<init>(UiPlugin.java:97)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 26 more
Root exception:
Source)
!ENTRY org.eclipse.ui.workbench 4 2 2006-05-21 10:24:16.789
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.hyades.statistical.ui was unable to load class
org.eclipse.hyades.statistical.ui.internal.viewsource.Startu p.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:407)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2006-05-21 10:24:16.789
!MESSAGE Plug-in org.eclipse.hyades.statistical.ui was unable to load
class org.eclipse.hyades.statistical.ui.internal.viewsource.Startu p.
!STACK 0
!STACK 0
!ENTRY org.eclipse.ui 4 4 2006-05-21 10:24:16.789
!MESSAGE Unhandled Exception
!ENTRY org.eclipse.hyades.statistical.ui 4 0 2006-05-21 10:24:16.789
!MESSAGE Unable to execute early startup code for an extension
!STACK 1
!STACK 0
!ENTRY org.eclipse.osgi 2 1 2006-05-21 10:27:10.243
!MESSAGE NLS unused message:
--------------------------------------------------- in:
org.eclipse.hyades.trace.ui.internal.util.messages
!ENTRY org.eclipse.hyades.trace.ui 4 0 2006-05-21 10:27:11.274
!MESSAGE Could not initialize class
!SESSION 2006-05-21 10:31:41.243
eclipse.buildId=I20060519-1206
java.version=1.6.0-beta
Command-line arguments: -os win32 -ws win32 -arch x86
Previous Topic:[AGR] Failure to locate local toolbar item in editor during playback
Next Topic:[AGR] Double click in StyledText?
Current Time: Tue Oct 28 02:36:45 EDT 2025
Powered by FUDForum. Page generated in 0.03436 seconds
