Home » Language IDEs » C / C++ IDE (CDT) » Tweaking commands that eclipse sends to gdb
Tweaking commands that eclipse sends to gdb [message #71355] Fri, 23 May 2003 18:06 Go to next message
Originally posted by: pbaranov.ubicom.com
The gdb commands that eclipse uses when a debug session gets started
doesn't work with my embedded target. I need to tweak this sequence of
commands but can't figure out where it is coded. Can anybody point me to
the right place.
Pavel
Re: Tweaking commands that eclipse sends to gdb [message #71413 is a reply to message #71355] Sun, 25 May 2003 12:45 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
What exactly do you want to change? You can use .gdbinit file to add
commands to the starting sequence.
"Pavel" <pbaranov@ubicom.com> wrote in message
news:bam61o$dnj$1@rogue.oti.com...
> the right place.
> Pavel
Re: Tweaking commands that eclipse sends to gdb [message #71431 is a reply to message #71355] Sun, 25 May 2003 14:54 Go to previous messageGo to next message
in package org.eclipse.cdt.debug.mi.core.command, the class CommandFactory
creates command sent to gdb.
> the right place.
> Pavel
Re: Tweaking commands that eclipse sends to gdb [message #71718 is a reply to message #71413] Tue, 27 May 2003 13:47 Go to previous messageGo to next message
I need to change:
target-select remote ip:port
to:
target ip2k ip:port
Pavel
> > the right place.
> > Regards,
> > Pavel
Re: Tweaking commands that eclipse sends to gdb [message #71756 is a reply to message #71718] Tue, 27 May 2003 14:23 Go to previous message
Originally posted by: mikhailk.qnx.com
You can do it by changing the "createLaunchSession" method of the
"org.eclipse.cdt.debug.mi.core.GDBServerDebugger" class.
news:bb08av$c72$1@rogue.oti.com...
> I need to change:
> to:
> target ip2k ip:port
> Pavel
to
> > > the right place.
> > > Regards,
> > > Pavel
Previous Topic:Functions in extern blocks not parsed?
Next Topic:Code Assist: Fact or Fantasy
Current Time: Fri Oct 31 01:46:55 EDT 2025
Powered by FUDForum. Page generated in 0.04128 seconds
