Home » Archived » BIRT » sending a report parameter as an argument to a function
| sending a report parameter as an argument to a function [message #71349] |
Fri, 02 September 2005 12:22  |
Originally posted by: sai.yelamanchili.gmail.com
I want to send a report parameter as an argument to a function in a java
class. I'm working on Scripted Data Source. Does anyone have any ideas
on this.
Help Appreciated.
Sai
| Re: Error [message #71597 is a reply to message #71579] |
Fri, 02 September 2005 15:14   |
Jason,
Its a date paramater. Its of Type DateTime.
Jason Weathersby wrote:
> Sai,
> Is your paramater a string?
> If so make sure its double quoted.
> Jason Weathersby
> BIRT PMC
> "Sai Yelamanchili" <sai.yelamanchili@gmail.com> wrote in message
> news:dfa75k$gme$2@news.eclipse.org...
>>Jason
>>Can You please tell me why do I get the following error :
>>"Some required parameter values are not set or set to incompatible data
>>type."
>>what parameter values is this referring to ?
>> I appreciate Your time and effort.
>>Thanks in advance
>>Sai
>>>Sai,
>>>You should be able to just add
>>>var x = new A().B(params["yourparametername"]);
>>>One caveat. Dont do this in the open method of the Data Source. I
>>>believe there is a problem with this.
>>>Try it on the Data Set open method.
>>>Jason Weathersby
>>>BIRT PMC
>>>news:dfa5mo$etj$1@news.eclipse.org...
>>>>Jason,
>>>>really looks like its gonna help me. Can you make this a little clear.
>>>>Suppose, if I'm referencing a class A and invoking function B(with
>>>>argument) of that class, I mean
>>>>In open() function:
>>>>importPackage(Packages x.x.x.x.);
>>>>var x = new A().B();
>>>>and now I need a argument to be set to B from a user input, how do I do
>>>>that ?
>>>>Thanks much!
>>>>Sai
>>>>>Sai,
>>>>>You should be able to do this.
>>>>>As an example I have a class that I use as an RSS reader and in my open
>>>>>method I use a parameter to set the feed.
>>>>>open method on Data Set
>>>>>brss = new Packages.org.birt.examples.sds.BirtRssReader();
>>>>>brss..setFeed(params["RssFeed"]);
>>>>>brss.readFeed();
>>>>>Jason Weathersby
>>>>>BIRT PMC
>>>>>news:df9vb6$6a3$1@news.eclipse.org...
>>>>>>Is there really a way to do this ? Does report parameters work with
>>>>>>Scripted Data Sources ? Is this supported ?
>>>>>>Thanks!
>>>>>>Sai Yelamanchili wrote:
>>>>>>>Hi,
>>>>>>>java class. I'm working on Scripted Data Source. Does anyone have any
>>>>>>>ideas on this.
>>>>>>>Help Appreciated.
>>>>>>>Thanks
>>>>>>>Sai
| Re: Error [message #71654 is a reply to message #71597] |
Fri, 02 September 2005 15:33   |
Sai,
Have you tried
var dt = new Date(params["yourparameter"]);
new A().B( dt);
Jason Weathersby
BIRT PMC
news:dfa88u$ich$1@news.eclipse.org...
> Jason,
> Thanks
>> Sai,
>> Jason Weathersby
>> BIRT PMC
>>>Jason
>>>type."
>>>Thanks in advance
>>>Sai
>>>>Sai,
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>Jason,
>>>>>In open() function:
>>>>>that ?
>>>>>Thanks much!
>>>>>Sai
>>>>>>Sai,
>>>>>>open method I use a parameter to set the feed.
>>>>>>brss.readFeed();
>>>>>>Jason Weathersby
>>>>>>BIRT PMC
>>>>>>>Thanks!
>>>>>>>>Hi,
>>>>>>>>any ideas on this.
>>>>>>>>Help Appreciated.
>>>>>>>>Thanks
>>>>>>>>Sai
| Re: Error [message #71673 is a reply to message #71654] |
Fri, 02 September 2005 15:38   |
Yes I did,
Error persists.
Sai
> Sai,
> Have you tried
> new A().B( dt);
> Jason Weathersby
> BIRT PMC
>>Jason,
>>Thanks
>>>Sai,
>>>Jason Weathersby
>>>BIRT PMC
>>>>Jason
>>>>type."
>>>>Thanks in advance
>>>>Sai
>>>>>Sai,
>>>>>Jason Weathersby
>>>>>BIRT PMC
>>>>>>Jason,
>>>>>>In open() function:
>>>>>>that ?
>>>>>>Thanks much!
>>>>>>Sai
>>>>>>>Sai,
>>>>>>>brss.readFeed();
>>>>>>>Jason Weathersby
>>>>>>>BIRT PMC
>>>>>>>>Thanks!
>>>>>>>>>Hi,
>>>>>>>>>any ideas on this.
>>>>>>>>>Help Appreciated.
>>>>>>>>>Thanks
>>>>>>>>>Sai
| Re: Error [message #71692 is a reply to message #71673] |
Fri, 02 September 2005 16:00   |
Sai,
I had a similar error in the past with a string parameter.
Have you checked the log file for anything under
org.eclipse.birt.report.viewer_1.0.1\birt\logs
Additionally is this the only paramter?
Jason Weathersby
BIRT PMC
news:dfa9m5$k4r$1@news.eclipse.org...
> Yes I did,
> Error persists.
> Thanks
> Sai
>> Sai,
>> Have you tried
>> new A().B( dt);
>> Jason Weathersby
>> BIRT PMC
>>>Jason,
>>>Thanks
>>>>Sai,
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>Jason
>>>>>type."
>>>>>Thanks in advance
>>>>>Sai
>>>>>>Sai,
>>>>>>Jason Weathersby
>>>>>>BIRT PMC
>>>>>>>Jason,
>>>>>>>clear.
>>>>>>>In open() function:
>>>>>>>do that ?
>>>>>>>Thanks much!
>>>>>>>Sai
>>>>>>>>Sai,
>>>>>>>>brss.readFeed();
>>>>>>>>Jason Weathersby
>>>>>>>>BIRT PMC
>>>>>>>>>Thanks!
>>>>>>>>>>Hi,
>>>>>>>>>>a java class. I'm working on Scripted Data Source. Does anyone
>>>>>>>>>>have any ideas on this.
>>>>>>>>>>Help Appreciated.
>>>>>>>>>>Thanks
>>>>>>>>>>Sai
| Re: Error [message #71709 is a reply to message #71692] |
Fri, 02 September 2005 16:20   |
Jason
This is the only parameter.
sai
> Sai,
> Jason Weathersby
> BIRT PMC
>>Yes I did,
>>Error persists.
>>Thanks
>>Sai
>>>Sai,
>>>Have you tried
>>>new A().B( dt);
>>>Jason Weathersby
>>>BIRT PMC
>>>>Jason,
>>>>Thanks
>>>>>Sai,
>>>>>Jason Weathersby
>>>>>BIRT PMC
>>>>>>Jason
>>>>>>type."
>>>>>>Thanks in advance
>>>>>>Sai
>>>>>>>Sai,
>>>>>>>Jason Weathersby
>>>>>>>BIRT PMC
>>>>>>>>Jason,
>>>>>>>>clear.
>>>>>>>>In open() function:
>>>>>>>>do that ?
>>>>>>>>Thanks much!
>>>>>>>>Sai
>>>>>>>>>Sai,
>>>>>>>>>brss.readFeed();
>>>>>>>>>Jason Weathersby
>>>>>>>>>BIRT PMC
>>>>>>>>>>Thanks!
>>>>>>>>>>>Hi,
>>>>>>>>>>>Help Appreciated.
>>>>>>>>>>>Thanks
>>>>>>>>>>>Sai
| Detailed Idea [message #72101 is a reply to message #71709] |
Mon, 05 September 2005 13:54   |
Jason
What I'm exactly doing is :
I have an object A and a class B. Class B has a function that takes an
argument "x", which is a date and returns ArrayList of A objects.
Now, I have to use the Scripetd Data Source to make a report from the
returned ArrayList.
In my open and fetch of Data Set, I'm usig the following code:
Open()
importPackage(Packages.com.rpc.core.accounting.model);
dt = new Date(params["input"]);
c = new B().A(dt);
itrLista = c.iterator();
Fetch()
while(itrLista.hasNext())
a = itrLista.next();
row["1"]= a.get1();
row["2"]= a.get2();
row["3"]= a.get3();
row["4"]= a.get4();
row["5"]= a.5();
return true;
return false;
" Some required parameter values are not set or set to incompatible data
type."
1. while creating the report parameter input, Do I have to select type
as String or Datetime.
And any other ideas how I can proceed with this. Cudnt't find any
online-help. I'm actually new to reporting.
I appreciate Ur help.
Sai
> Jason
> Thanks
> sai
>> Sai,
>> Jason Weathersby
>> BIRT PMC
>>> Yes I did,
>>> Error persists.
>>> Thanks
>>> Sai
>>>> Sai,
>>>> Have you tried
>>>> new A().B( dt);
>>>> Jason Weathersby
>>>> BIRT PMC
>>>>> Jason,
>>>>> Thanks
>>>>>> Sai,
>>>>>> Jason Weathersby
>>>>>> BIRT PMC
>>>>>>> Jason
>>>>>>> incompatible data type."
>>>>>>> Thanks in advance
>>>>>>> Sai
>>>>>>>> Sai,
>>>>>>>> I believe there is a problem with this.
>>>>>>>> Jason Weathersby
>>>>>>>> BIRT PMC
>>>>>>>>> Jason,
>>>>>>>>> clear.
>>>>>>>>> B(with argument) of that class, I mean
>>>>>>>>> In open() function:
>>>>>>>>> do I do that ?
>>>>>>>>> Thanks much!
>>>>>>>>> Sai
>>>>>>>>>> Sai,
>>>>>>>>>> in my open method I use a parameter to set the feed.
>>>>>>>>>> brss.readFeed();
>>>>>>>>>> Jason Weathersby
>>>>>>>>>> BIRT PMC
>>>>>>>>>> message news:df9vb6$6a3$1@news.eclipse.org...
>>>>>>>>>>> work with Scripted Data Sources ? Is this supported ?
>>>>>>>>>>> Thanks!
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> function in a java class. I'm working on Scripted Data
>>>>>>>>>>>> Source. Does anyone have any ideas on this.
>>>>>>>>>>>> Help Appreciated.
>>>>>>>>>>>> Thanks
>>>>>>>>>>>> Sai
| Re: Detailed Idea [message #72121 is a reply to message #72101] |
Mon, 05 September 2005 14:42  |
Jason
returned ArrayList.
Open()
c = new B().A(dt);
Fetch()
row["1"]= a.get1();
row["2"]= a.get2();
row["3"]= a.get3();
row["4"]= a.get4();
row["5"]= a.5();
return true;
return false;
type."
After I enter the date,
the error is:
" Script engine error: TypeError: findOpenDepositsAsOfDate is not a
function. (DataSet:OpenVendorDeposit.open#2 "
Sai
> Jason
> returned ArrayList.
> Open()
> c = new B().A(dt);
> Fetch()
> row["1"]= a.get1();
> row["2"]= a.get2();
> row["3"]= a.get3();
> row["4"]= a.get4();
> row["5"]= a.5();
> return true;
> return false;
> type."
> Thanks
> Sai
>> Jason
>> Thanks
>> sai
>>> Sai,
>>> Jason Weathersby
>>> BIRT PMC
>>>> Yes I did,
>>>> Error persists.
>>>> Thanks
>>>> Sai
>>>>> Sai,
>>>>> Have you tried
>>>>> new A().B( dt);
>>>>> Jason Weathersby
>>>>> BIRT PMC
>>>>>> Jason,
>>>>>> Thanks
>>>>>>> Sai,
>>>>>>> Jason Weathersby
>>>>>>> BIRT PMC
>>>>>>>> Jason
>>>>>>>> Thanks in advance
>>>>>>>> Sai
>>>>>>>>> Sai,
>>>>>>>>> Source. I believe there is a problem with this.
>>>>>>>>> Jason Weathersby
>>>>>>>>> BIRT PMC
>>>>>>>>> message news:dfa5mo$etj$1@news.eclipse.org...
>>>>>>>>>> Jason,
>>>>>>>>>> little clear.
>>>>>>>>>> In open() function:
>>>>>>>>>> how do I do that ?
>>>>>>>>>> Thanks much!
>>>>>>>>>> Sai
>>>>>>>>>>> Sai,
>>>>>>>>>>> brss.readFeed();
>>>>>>>>>>> Jason Weathersby
>>>>>>>>>>> BIRT PMC
>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> Help Appreciated.
>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>> Sai
Current Time: Sun Nov 09 03:31:28 EST 2025
Powered by FUDForum. Page generated in 0.06723 seconds
