Home » Newcomers » Newcomers » debugging rt.jar
debugging rt.jar [message #71342] Mon, 30 May 2005 05:51 Go to next message
Hi all,
I would like to step through and debug rt.jar
So far I have created an eclipse project and unzipped src.zip and allowed
eclipse to compile it, after which I jarred it back up into myrt.jar. I then
specifed this on the buid path for the project I wished to debug.
My problem is that Eclipse still complains with "absent line number
information" even thou' I ticked the checkbox to include them from within
Eclpise when I compiled the classes.
Can anyone help or has anyone been able to debug rt.jar?
Re: debugging rt.jar [message #71711 is a reply to message #71342] Tue, 31 May 2005 14:04 Go to previous messageGo to next message
I am not sure what is the problem there.
Debugging/stepping through rt works fine out of the box, ass leasst when you
use a JDK.
No need for re-compile, and all that pain.
Just works out of the box.
What is your version/config?
"Martin Holmes" <martincanbe@hotmail.com> wrote in message
news:d7f6ku$dsn$1@news.eclipse.org...
> Hi all,
then
> Thanks
Re: debugging rt.jar [message #71823 is a reply to message #71711] Wed, 01 June 2005 05:13 Go to previous messageGo to next message
Hi I am running windows 2000 and using Eclipse 3.1M6.
I am also using the rt.jar located on my machine at;
C:\j2sdk1.4.2_05\jre\lib\rt.jar
I have read that by default Sun does not compile rt.jat with debug
infomation due to increased download size.
thank you
"Philippe Ombredanne" <pombredanne@nexb.com> wrote in message
news:d7i9c5$u6b$1@news.eclipse.org...
you
> use a JDK.
> > Hi all,
allowed
> then
within
> > Thanks
Re: debugging rt.jar [message #71918 is a reply to message #71823] Wed, 01 June 2005 10:08 Go to previous messageGo to next message
While I don't know *why* Sun does not offer an rt.jar with debug info
compiled in, it is a fact that they do not. It is possible to step
through the Java core classes that are in rt.jar, but they don't have
local variable information available when you do. That is the limitation
that people speak of, not that you can't step through them at all.
HTH,
Eric
Re: debugging rt.jar [message #72030 is a reply to message #71823] Wed, 01 June 2005 12:41 Go to previous messageGo to next message
news:d7ju2m$li5$1@news.eclipse.org...
I do not know what kind of magic Eclipse is doing behind the scene, but I
never had a problem there, and have always been able to step through JRE
code nicely.
AFAIK the rt.jar that is under the JDK has been compiled in debug and is
about 4MB bigger than the rt.jar in the public JRE.
Are you sure that Eclipse runs under the JDK as opposed to the public JRE
that comes with it?
And try to start eclipse with a specific JDK:
eclipse.exe -vm c:\j2sdk1.4.2_08\bin\javaw.exe (assuming you have the
1.4.2_08 JDK installed at that location...)
Re: debugging rt.jar [message #73933 is a reply to message #72030] Sun, 05 June 2005 07:59 Go to previous message
Hi again,
it seems the problem is the version of Eclipse I was using.
Infact I tried Eclipse M6 and M7 and both gave the same error. However when
I downloaded the Eclipse release build 3.02 which I believe has no Java 5.0
support and used jdk1.4 everything worked fine. I even recompiled with full
debug attributes and that gave me all the deug information I could possibly
dream of :)
I am now wondering if this a known bug in the Eclpise 3.1 milestone builds.
Hmm how do I find out..... Perhaps I should report it!
Thanks again
news:d7kotp$qvn$3@news.eclipse.org...
> code nicely.
> that comes with it?
Previous Topic:Eclipse Bug - welcome & help
Next Topic:SWT - Drop and drag
Current Time: Mon Oct 27 10:50:35 EDT 2025
Powered by FUDForum. Page generated in 0.09280 seconds
