Home » Eclipse Projects » Eclipse Platform » More on problems importing binary projects
More on problems importing binary projects [message #71295] Wed, 11 June 2003 13:05 Go to next message
Originally posted by: vde.uiuc.edu
hi,
this is with reference to the mail i sent a while back about the problems
i'm facing in importing binary projects. i thought it would be helpful to
give a list of all the error messages i got when i imported the jar file.
the project i tried to import the jar file into is called
org.eclipse.cexample.
Description Resource
The project was not built due to classpath errors
(incomplete or involved in cycle)
Missing required Java project: org.apache.xerces
Missing required Java project: org.eclispe.compare
Missing required Java project: org.eclipse.core.boot
Missing required Java project: org.eclipse.core.resources
Missing required Java project: org.eclipse.core.runtime
Missing required Java project: org.eclipse.debug.core
Missing required Java project: org.eclipse.debug.ui
Missing required Java project: org.eclipse.jdt.ui
Missing required Java project: org.eclipse.search
Missing required Java project: org.eclipse.ui
Re: More on problems importing binary projects [message #71451 is a reply to message #71295] Wed, 11 June 2003 15:14 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Another append in this newsgroup I just made answers this question.
See topic: Re: HElp!!! big pb with plugin.xml
timestamp: 10:02 AM
author: Richard L. Kulp
Previous Topic:Opening an editor redux
Next Topic:Problem using JUnit in eclipse
Current Time: Sat Nov 22 04:30:21 EST 2025
Powered by FUDForum. Page generated in 0.03461 seconds
