Home » Archived » M2M (model-to-model transformation) » [ATL] resolveTemp
| [ATL] resolveTemp [message #71266] |
Wed, 09 January 2008 11:29  |
I am using the function resolveTemp for setting references in several
rules. But when some element could not be resolved, the function
crashes. Is this behavior intended? If not, how can I test whether a
source element was translated or not?
Sebastian
| Re: [ATL] resolveTemp [message #71326 is a reply to message #71266] |
Wed, 09 January 2008 11:33   |
Originally posted by: mikael.barbero.gmail.com
Dear Sebastian,
If some elements could not be resolved, it means they were not matched
by any rule. You have to check this manually.
Could you post your metamodel and an excerpt of your transformation and
tell us where it crashes?
Mikael
bfeater wrote:
> Sebastian
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
| Re: [ATL] resolveTemp [message #71403 is a reply to message #71326] |
Thu, 10 January 2008 04:09   |
Mikaël Barbero schrieb:
> Dear Sebastian,
in my setting it is intended not to match all elements (because the
elements are not well defined, etc.). But in the translation of other
elements I need to know whether an element was or will be translated.
How can I check this manually? Creating a global Set storing translated
elements (by a statement in the do section of the corresponding rule)
would not fit, right?
I would assume that resolveTemp returns OclUndefined when the element
is/will be not translated.
The translation rules are very extensive. The crash happens in the
following assignment (but only when the element to resolve is not created):
end <- thisModule.resolveTemp (uml_p, 'hrc_f'),
Best regardc,
Sebastian
> Best regards,
> Mikael
> bfeater wrote:
>> Thanks,
>> Sebastian
| Re: [ATL] resolveTemp [message #71460 is a reply to message #71403] |
Thu, 10 January 2008 05:28   |
Hi Sebastian,
My answer below
When I was talking about checking this manually, I was thinking of not
calling a resolveTemp on some elements that will not actually be
transformed.
Right, tough because your are not sure about the order of the execution
of the rules. You should only do something local to a rule in a "do"
section.
In fact, you want to be sure that your elements has been filtered out by
some rules (which mean it have been transformed). I suggest to make all
of your filter of matched rule as an boolean helper and test it on each
element on which you want to call resolveTemp. Having this source metamodel:
class A {}
class B {}
class C {}
and those rules
rule A2Foo {
from
s : MM!A (
an_exp_on_MM!A
to
anAttribute <- thisModule.resolveTemp(s.something, 'tgtPatternElem')
rule B2Bar {
from
s : MM!B (
an_exp_on_MM!B
to
you can do three helpers:
helper context MM!A def: transformIt : Boolean =
an_exp_on_MM!A;
helper context MM!B def: transformIt : Boolean =
an_exp_on_MM!B;
helper context MM!C def: transformIt : Boolean =
false; -- MM!C are never matched in my transformation, then i return
false
and rewrite your rules:
rule A2Foo {
from
s : MM!A (
s.transformIt
to
anAttribute <- if (s.something.transformIt) then
thisModule.resolveTemp(s.something, 'tgtPatternElem') else OclUndefined
endif
-- or if s.something is multivalued
anAttribute <- s.something->collect(e | if (e.transformIt) then
thisModule.resolveTemp(e, 'tgtPatternElem') else OclUndefined endif)
rule B2Bar {
from
s : MM!B (
s.transformIt
to
There is no performance penalty because transformIt are attribute
helpers and are cached by the engine.
You're right, it should to have a similar behavior as the default
resolve. Can you open a bug about this?
Mikael
| Re: [ATL] resolveTemp [message #71498 is a reply to message #71460] |
Thu, 10 January 2008 05:34  |
> Hi Sebastian,
> My answer below
> transformed.
>> Creating a global Set storing translated elements (by a statement in
>> the do section of the corresponding rule) would not fit, right?
> section.
ok, that was my consideration.
> metamodel:
> class A {}
> class B {}
> class C {}
> and those rules
> rule A2Foo {
> from
> s : MM!A (
> an_exp_on_MM!A
> to
> rule B2Bar {
> from
> s : MM!B (
> an_exp_on_MM!B
> to
> an_exp_on_MM!A;
> an_exp_on_MM!B;
> false
> rule A2Foo {
> from
> s : MM!A (
> s.transformIt
> to
> endif
> rule B2Bar {
> from
> s : MM!B (
> s.transformIt
> to
Ok, thats the way I realized it. My source meta-model is UML and so I
added an attribute isTranslated to UML!Element which indicates whether
an element is translated or not.
And befor I want to call resolveTemp I test whether the source element
Yes.
> Best regards,
> Mikael
Thank you for the quick help
Sebastian
Current Time: Thu Nov 20 05:44:38 EST 2025
Powered by FUDForum. Page generated in 0.02787 seconds
