| Eclipse/CDT and embedded development [message #71180] |
Thu, 22 May 2003 14:46  |
Originally posted by: pbaranov.ubicom.com
I wonder if anybody has used Eclipse/CDT in embedded development. I\'m
trying to use Eclipse/CDT under windows to develop code for an 8-bit
microprocessor using gnu toolchain but have problems. I can\'t start
debugger and because I don\'t see any gdb output inside Eclipse (like I
see if I start gdb from command line in non gui mode) I can\'t figure out
what goes wrong. (I suspect that I just haven\'t figured out how to turn
on the gdb output, can\'t believe that this feature is just missing)
Any suggestions.
Also please reply if you have succesfully used Eclipse/CDT in embedded
development.
Pavel
| Re: Eclipse/CDT and embedded development [message #71278 is a reply to message #71259] |
Thu, 22 May 2003 18:05  |
John Miller wrote:
> I'm not an expert but just got my cross-env running (on a linux box)
> I know this is obvious, but is the gdb exe in your path?? Also if your
Yes it is but this is one of the things that confuse me in eclipse. Why do
I have to have gdb in my path if I can specify full path inside the Debug
options dialog.
> debugging a remote target, I believe that gdbserver needs to be running on
> that target.
There is a problem using the gdb server (it's the only option where I can
specify IP:port of my target). Because the Debugger dialog with "GDB
Server" option selected has a "Load shared library symbols automatically"
I suppose that CDT developers assume that this will always be under linux.
But I need to debug my remote target under windows/cygwin. (I can debug it
using gdb started from command line and using another windows based gui)
Anyway I'm stuck getting "Failed Launching CDI Debugger: Error
initializing: Malformed response to offset query, timeout". Is there any
way to see what was sent to gdb, what was received back and what was
expected? Don't see a way how to get this info.
Pavel
> good luck
> > Any suggestions.
> > development.
> > Regards,
> > Pavel
FUDForum. Page generated in 0.04111 seconds
