| Actions [message #71075] |
Mon, 17 March 2003 17:04  |
Originally posted by: melaasar.rational.com
My first question is : is there a reason why GEF ties the action hierarchy
to IEditorPart rather than IWorkbenchpart? It is complicating the effort of
hosting GEF viewers in other parts like JFace views.
My second question: GEF is inheriting RetargetAction, which is not intended
to be subclassed according to the Eclipse docs. Is there a necessity for
that?
My third question: GEF is also reusing the retargetable actions concept to
redirect action handlers to different instances of the same editor kind. I
thought this concept is introduced in Eclipse mainly for retargeting actions
across different workbench parts. The question is: why cannot GEF conform to
Eclipse's intended way of retargetting different instances of the same part
kind by using ActionDelegates?
I appreciate any feedback and thanks very much in advance
Maged
| Re: Actions [message #71117 is a reply to message #71075] |
Mon, 17 March 2003 17:24   |
"Maged Elaasar" <melaasar@rational.com> wrote in message
news:b55gm4$gib$1@rogue.oti.com...
> Hello,
of
You mean workbench views? It probably isn't necessary now. We used to
obtain various notifiers from the IEditorPart, but now the Actions don't
listen to anything. They require manual updating.
If you want this changed, you'll have to bring it up on the development
mailing list. this sounds like a source-compatible change, but not a
binary-compatible change. Since we haven't released 2.1 yet, it might be
acceptable to make this type of change.
intended
> that?
Our subclasses do nothing but set initial values for text and icon. We do
not override any methods, so I think that this type of subclassing provides
convenience to the client. Otherwise, you would be required to set the ID,
text, defitionID, description, rollover icon, disabled icon, and standard
icon.
actions
to
part
We are doing exactly what the Eclipse TextEditor does. ActionDelegates are
used by extension points. When adding actions programmatically, they are
not needed.
> Maged
| Re: Actions [message #71304 is a reply to message #71117] |
Tue, 18 March 2003 11:34  |
Randy,
I appreciate your feedback. I have one more comment:
As you said, extending from the Action class is good for programatically
defined actions. However, for extensibility reasons, you would want to
extend from ActionDelegate. This is extremely useful for a GEF application
with different deployable plugins that contribute their actions to the main
application. In this case, you would have to create and maintain a separate
action hierarchy (off ActionDelegate) for that. On the other hand, making a
single hierarchy that extends off the Action Delegates would be sufficient
whether extensibility is or is not required. You will also get the
retargetability for free using this mechanism.
Please let me know what you think about this.
Maged
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b55i08$hfi$1@rogue.oti.com...
> > Hello,
hierarchy
> of
> intended
> > that?
provides
ID,
> icon.
to
I
> actions
conform
> to
> part
are
> not needed.
> > Maged
FUDForum. Page generated in 0.03911 seconds
