Home » Archived » Test and Performance Tools Platform (TPTP) » Large Application - No data is available for display
Large Application - No data is available for display [message #70907] Mon, 15 May 2006 23:52 Go to next message
Profiling a small application seems to work without a problem. With a
large, Swing-based application I get only:
"No data is available for display.
The object selected in the Profiling Monitor view does not contain this
type of information. .."
On any of the panels that I can access with "Open With" (pressing the
"Link With Viewer" seems to have no effect).
I've tried a number of different profiling options, but is we consider
just "Basic Memory Analysis". Now consider the "Memory Statistics" tab.
For the small application I see useful things, for the large application,
just the error message. I'm running the same "profiling set" in both
cases and as far as I can tell, everything is the same except the nature
of the applications.
Are there some parameters that need to be tweaked to debug large
application (or Swing?). Is there something obvious that I'm missing?
In case it's useful the application runs more than a factor of 10 slower
than when just debugging.
Jim
Re: Large Application - No data is available for display [message #70926 is a reply to message #70907] Tue, 16 May 2006 10:24 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 004F2A2185257170_=
Content-Type: text/plain; charset="US-ASCII"
Make sure you're not accidentally filtering out your classes. Please see:
http://www.eclipse.org/newsportal/article.php?id=2046&gr oup=eclipse.tptp#2046
For suggestions on how you can speed up the profiler, see:
http://dev.eclipse.org/mhonarc/lists/tptp-tracing-profiling- tools-dev/msg00219.html
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Make sure you're not accidentally filtering
out your classes. &nbsp;Please see: http://www.eclipse.org/newsportal/article.php?id=2046&am p;group=eclipse.tptp#2046</font>
<br>
<br><tt><font size=2>&gt;In case it's useful the application runs more
than a factor of 10 slower <br>
&gt;than when just debugging.<br>
</font></tt>
<br><font size=2 face="sans-serif">For suggestions on how you can speed
up the profiler, see: http://dev.eclipse.org/mhonarc/lists/tptp-tracing-profiling- tools-dev/msg00219.html</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 004F2A2185257170_=--
Re: Large Application - No data is available for display [message #71007 is a reply to message #70926] Tue, 16 May 2006 11:39 Go to previous messageGo to next message
I'm no expert here but to the best of my knowledge the filter is correct.
I'm also using the same profiling set on the smaller application which
work.
As the application starts, in the shell that started eclipse, I get this
exception. Any insight here?
java.io.EOFException: Unexpected end of ZLIB input stream
java.util.zip.InflaterInputStream.fill(InflaterInputStream.j ava:216)
java.util.zip.InflaterInputStream.read(InflaterInputStream.j ava:134)
at java.util.zip.ZipInputStream.read(ZipInputStream.java:139)
org.eclipse.hyades.trace.ui.internal.piclient.XMLTraceDataPr ocessor.copyZip(XMLTraceDataProcessor.java:291)
org.eclipse.hyades.trace.ui.internal.piclient.XMLTraceDataPr ocessor.makeWriter(XMLTraceDataProcessor.java:225)
org.eclipse.hyades.trace.ui.internal.piclient.XMLTraceDataPr ocessor.createWriter(XMLTraceDataProcessor.java:203)
org.eclipse.hyades.trace.ui.internal.piclient.PIProcessListe ner.agentActive(PIProcessListener.java:199)
org.eclipse.hyades.internal.execution.local.control.AgentImp l.handleCommand(AgentImpl.java:508)
org.eclipse.hyades.internal.execution.local.control.ProcessI mpl.handleCommand(ProcessImpl.java:638)
org.eclipse.hyades.internal.execution.local.control.ProcessI mpl$1.incommingCommand(ProcessImpl.java:147)
org.eclipse.hyades.internal.execution.local.control.Connecti onImpl$1.incommingCommand(ConnectionImpl.java:178)
org.eclipse.hyades.internal.execution.local.control.Connecti onImpl.processControlMessage(ConnectionImpl.java:413)
org.eclipse.hyades.internal.execution.local.control.Connecti onImpl$SocketReaderThread.run(ConnectionImpl.java:506)
Re: Large Application - No data is available for display [message #71045 is a reply to message #71007] Tue, 16 May 2006 14:04 Go to previous message
--=_alternative 0063431985257170_=
Are you profiling to a file by any chance? In your launch configuration,
when you click on the destination tab, is the 'send profiling data to a
file' checked?
Navid Mehregani
<br><font size=2 face="sans-serif">Are you profiling to a file by any chance?
&nbsp;In your launch configuration, when you click on the destination tab,
is the 'send profiling data to a file' checked?</font>
<br>
--=_alternative 0063431985257170_=--
Previous Topic:AGR questions
Next Topic:Profiling A Simple Application
Current Time: Wed Nov 19 01:13:59 EST 2025
Powered by FUDForum. Page generated in 0.04238 seconds
