Home » Archived » Test and Performance Tools Platform (TPTP) » profile plugin
profile plugin [message #70762] Sat, 13 May 2006 14:22 Go to next message
Originally posted by: irbull.cs.uvic.ca
Hi All,
I am doing some testing for the Callisto release, and I thought I would
try my hand at TPTP. I have D/L the the latest (4.2 and all
dependencies). It seems to start fine and I can profile a simple Java
application. I then tried to profile an eclipse plugin. I wrote a
simple plugin, launched my runtime workbench, and it worked fine. I
then tried to profile my runtime workbench (profile as-> eclipse
application). The profiler seems ok, but my plugin isn't there.
Actually no plugins from my original workbench are there.
The profiler was launched with (All workspace and enabled external
plug-ins). (Same launch configuration I used to test my plugin).
Is this supposed to work, or is there something fundamental I am missing?
Ian
Re: profile plugin [message #70770 is a reply to message #70762] Sun, 14 May 2006 23:40 Go to previous messageGo to next message
I have this problem too.
The plugin to be profiled just can't be seen int the profile tab.
It seems that only some standard plugin can be profiled.
BTW: Ian, what view can you see when you just profile these standard
plugin.
I see nothing but something like
"no data is avaliable for display. The object selected in the profiling
monitor views does not contain this type information."
I selected the profile option and nothing change.
I run TPTP4.1.0.1 on eclpse 3.1.2 on linux.
Re: profile plugin [message #70781 is a reply to message #70770] Mon, 15 May 2006 11:03 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0052BCA98525716F_=
Content-Type: text/plain; charset="US-ASCII"
Make sure you're not accidentally filtering out your plugins. In TPTP
4.1, go to your profile launch configuration: click on the profile button
-> select 'profile..' -> select your launch configuration -> click on the
profiling tab -> select your profiling set -> edit -> next -> select your
profiling option -> next -> check your filterset here and make sure you're
not accidentally filtering out your plugin. Note by default all classes
in the org* packages are filtered out.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Make sure you're not accidentally filtering
out your plugins. &nbsp;In TPTP 4.1, go to your profile launch configuration:
click on the profile button -&gt; select 'profile..' -&gt; select your
launch configuration -&gt; click on the profiling tab -&gt; select your
profiling set -&gt; edit -&gt; next -&gt; select your profiling option
-&gt; next -&gt; check your filterset here and make sure you're not accidentally
filtering out your plugin. &nbsp;Note by default all classes in the org*
packages are filtered out.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 0052BCA98525716F_=--
Re: profile plugin [message #70870 is a reply to message #70770] Mon, 15 May 2006 18:13 Go to previous messageGo to next message
Thanks Ben, I had this problem too. Look at Navid's response, I was
filtering my code so nothing was bring recorded.
ian
> plugin.
Re: profile plugin [message #71288 is a reply to message #70870] Thu, 18 May 2006 22:12 Go to previous message
Navid, the tracing tab will not show the wanted plugin even you set
every filter to be "inclue".
Anyone interested in profiling eclispe plugin itself can use this plugin:
Eclipse Core Tools plug-in
Eclipse core tools plug-in can be used for plug-in developers to
monitor plugin startup time and memory usage(memory usage function need
ibm jdk support).
webpages about this plugin:
Plug-in homepage:
http://www.eclipse.org/eclipse/platform-core/downloads.html
introduction doc:
http://www-128.ibm.com/developerworks/opensource/library/os- ecspy1/
The latest core tools version 1.3.0 can run in eclipse 3.1.2
environment.
Previous Topic:Profiling A Simple Application
Next Topic:How to test eclipse plugin performance
Current Time: Fri Nov 07 18:55:52 EST 2025
Powered by FUDForum. Page generated in 0.04477 seconds
