| Can't watch Swing in design view [message #70758] |
Tue, 09 November 2004 07:15  |
I have installed eclipse 3.0.1, GEF 3.0.1, EMF 2.1.0 and VE 1.0.1.1 .
I can't watch Swing or AWT code (incl. eclipse examples) in the design
view of VE. If I start a new example class, code are generated but no view
in the design window and no items in the Bean-View. I can create new
components in design window, the code for a variable and get-methode are
created, but not added to the automatic build JPanel of the example. Only
I can view the frame with RUN>Application (implemented main), but without
JavaBean.
What must I do to watch Swing in dwsign view?
| Re: Can't watch Swing in design view [message #71048 is a reply to message #70763] |
Wed, 10 November 2004 06:02  |
Joe Winchester wrote:
> Hi Ralf,
>> view in the design window and no items in the Bean-View. I can create
>> new components in design window, the code for a variable and get-methode
>> are created, but not added to the automatic build JPanel of the example.
>> Only I can view the frame with RUN>Application (implemented main), but
>> without JavaBean.
> Is there anything written to the .log file ? This is in the .metadata
> directory of the workspace.
> What operating system and JRE level are you using ?
> Best regards,
> Joe Winchester
Thanks for trying to help.
I found the error by myself, it was a fault between VE plug-in and EMF
example plug-in. I disabled EMF example plug-in and VE ran proper.
| Re: Can't watch Swing in design view [message #602812 is a reply to message #70758] |
Tue, 09 November 2004 10:06  |
Hi Ralf,
> without JavaBean.
Joe Winchester
| Re: Can't watch Swing in design view [message #602913 is a reply to message #70763] |
> Hi Ralf,
>> without JavaBean.
> Best regards,
> Joe Winchester
FUDForum. Page generated in 0.03324 seconds
