| [ATL] run configuration cannot select ATL file [message #70738] |
Tue, 08 January 2008 04:03  |
When I'm configuring the Run of a given ATL file, the first time I do it it
works all fine (see screenshot 1). However the second time I click on run I
get an error that Path must include project and resource name. If I open
the run configuration dialog I cannot select the ATL file anymore (see
screenshot 2).
Am I doing something wrong or is this a bug?
| Re: [ATL] run configuration cannot select ATL file [message #70826 is a reply to message #70808] |
Tue, 08 January 2008 05:38  |
Rene Ladan wrote:
> Aram Hovsepyan wrote:
>> I do it it
>> I get an error that Path must include project and resource name. If I
>> open the run configuration dialog I cannot select the ATL file anymore
>> (see screenshot 2).
>> Thanks
> The screenshots didn't make it, but I had the same problem yesterday
> evening on my box. I installed Eclipse 3.3.1 on it (from source), then the
> precompiled versions of
> EMF 2.3.1 and ATL 2.0.0 (and some other stuff) via the update sites. This
> is on FreeBSD 7.0-BETA4 and a natively compiled jdk 1.5. Maybe the native
> jdk1.6 works.
> A workaround is to save the configuration to a launch file and edit that
> file manually before running it via the right-click menu.
> HTH,
> Rene
Indeed. Another way to solve this is by downloading the latest CVS snapshot.
greetings,
Aram.
FUDForum. Page generated in 0.05712 seconds
