Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2
For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #70737] Wed, 07 February 2007 12:12 Go to next message
For those using Teneo from cvs. I am working on upgrading Teneo to EMF 2.3/jdk 1.5. The related
changes are being made in cvs HEAD.
The EMF 2.2 release of Teneo is from now maintained in the R0_7_maintenance branch.
To switch your current version to the maintenance branch right click on each project and select:
Replace With > Another Branch or Version
Click Refresh Tags and the R0_7_maintenance branch should show up, select it and click ok.
I will be doing builds for both EMF 2.2 and EMF 2.3. The EMF 2.2 builds with be called maintenance
builds (build id starts with M), the EMF 2.3 builds will be so-called integration build (build id
starts with I).
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #70873 is a reply to message #70737] Wed, 07 February 2007 23:37 Go to previous messageGo to next message
So does moving to EMF 2.3 really mean having to upgrade to Eclipse 3.3
as it states in the EMF 2.3 upgrade plan or does it still work in an
Eclipse 3.2.1 environment?
Brian
Martin Taal wrote:
> 2.3/jdk 1.5. The related changes are being made in cvs HEAD.
> each project and select: Replace With > Another Branch or Version
> with be called maintenance builds (build id starts with M), the EMF 2.3
> builds will be so-called integration build (build id starts with I).
Re: For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #70974 is a reply to message #70873] Thu, 08 February 2007 07:07 Go to previous message
Brian,
The platform did deprecate APIs in 3.3 and provided new replacements
which we have started using so I don't think EMF 2.3 will function well
in Eclipse 3.2.x.
> Brian
> Martin Taal wrote:
>> EMF 2.3/jdk 1.5. The related changes are being made in cvs HEAD.
>> on each project and select: Replace With > Another Branch or Version
>> builds with be called maintenance builds (build id starts with M),
>> starts with I).
Re: For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #602329 is a reply to message #70737] Wed, 07 February 2007 23:37 Go to previous message
Brian
Martin Taal wrote:
Re: For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #602351 is a reply to message #70873] Thu, 08 February 2007 07:07 Go to previous message
Brian,
in Eclipse 3.2.x.
> Brian
> Martin Taal wrote:
>> starts with I).
Previous Topic:[Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotations w
Next Topic:Converting .ecore to .genmodel (EMF/GMF)
Current Time: Thu Jul 17 11:23:50 EDT 2025
Powered by FUDForum. Page generated in 0.03432 seconds
