Home » Archived » XML Schema Definition (XSD) » Referenced attributes
Referenced attributes [message #70674] Thu, 23 November 2006 05:02 Go to next message
i have a little problem by retrieving of top-level attributes referenced
in <xsd:attribute/> by "ref".
E.g. we have the following schema:
<!-- top level attribute -->
<xsd:attribute name="attr1" type="xsd:string"/>
<!-- complex type that reference that attribute -->
<xsd:complexType name="complexType1">
<xsd:attribute ref="attr1"/>
</xsd:complexType>
<!-- complex type that extends defined above complex type -->
<xsd:complexType name="extComplexType1">
<xsd:complexContent>
<xsd:extension base="complexType1">
<xsd:attribute name="extAttr1" type="xsd:string" />
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
1. I can reach the attribute "attr1" on the complex type "complexType1" by
calling of XSDComplexTypeDefinition#getAttributeContents instead of
XSDComplexTypeDefinition#getAttributeUses
2. XSDComplexTypeDefinition#getAttributeContents on the extension
"extComplexType1" doesn't return the "attr1" in the list, so i should
check all my base types recursive to find all "ref"-attributes that i
missing.
So here is my first question - how can i distinguish those
"ref"-attributes from the "normal"? - it seems to be also the instance of
XSDAttributeUse in the list, returned by
And why don't return the "ref"-attributes in
XSDComplexTypeDefinition#getAttributeUses like by referencing of an
attribute group? What is the difference?
thanks and warm regards,
Alexander
Re: Referenced attributes [message #70689 is a reply to message #70674] Thu, 23 November 2006 05:26 Go to previous messageGo to next message
Alexander,
Comments below.
Alexander Koezle wrote:
> referenced in <xsd:attribute/> by "ref".
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> "complexType1" by calling of
If you are doing semantic analysis, rather than syntactic analysis,
you'd probably want to use the later rather than the former.
> missing.
Yep. In the syntax, extAttr1 is all that appears in the
extComplexType1, so you'd have to follow all the syntax up the
inheritance chain to find all things this way.
> of XSDAttributeUse in the list, returned by
Given an XSDAttributeUse, getContent and getAttributeDeclaration will
return different things in the case of an attribute reference. In that
case, the former will return an XSDAttributeDeclaration for which
isAttributeDeclarationReference is true and the later will return the
getResolvedAttributeDeclaration. So if getContent and
getAttributeDeclarations return different things (and when
getContent().isAttributeDeclarationReference() is true), then you are
looking at an attribute declaration reference.
> attribute group?
I'm not sure I understand this comment. The getAttributeUses will
return exactly what's specified in the XML Schema specification, i.e.,
the set of attributes uses of the complex type.
If I understand correctly, the difference is between semantics (which
follows what the XML Schema specification says) verses syntax, which
models exactly the concrete syntax so that you can manipulate it directly.
> Alexander
Re: Referenced attributes [message #70703 is a reply to message #70674] Thu, 23 November 2006 05:46 Go to previous messageGo to next message
sorry, forget it
i have defined that "ref" as "prohibited" (not in the example), great
Re: Referenced attributes [message #70815 is a reply to message #70689] Thu, 23 November 2006 05:51 Go to previous messageGo to next message
hi Ed,
thank you for your quick answer and your explanations.
getContent().isAttributeDeclarationReference() works
best regards
Alexander
Re: Referenced attributes [message #70828 is a reply to message #70703] Thu, 23 November 2006 06:05 Go to previous message
Alexander,
Yeah. Prohibited attributes effectively disappear from the semantic
model for the restricted complex type. Just as the base content type is
completely replaced by a new version of it for a restricted type.
> sorry, forget it
Re: Referenced attributes [message #599161 is a reply to message #70674] Thu, 23 November 2006 05:26 Go to previous message
Alexander,
Comments below.
> </xsd:complexType>
> </xsd:extension>
> </xsd:complexType>
> missing.
> attribute group?
> Alexander
Re: Referenced attributes [message #599168 is a reply to message #70674] Thu, 23 November 2006 05:46 Go to previous message
sorry, forget it
Re: Referenced attributes [message #599175 is a reply to message #70689] Thu, 23 November 2006 05:51 Go to previous message
hi Ed,
best regards
Alexander
Re: Referenced attributes [message #599184 is a reply to message #70703] Thu, 23 November 2006 06:05 Go to previous message
Alexander,
> sorry, forget it
Previous Topic:Referenced attributes
Next Topic:URIConverter question.
Current Time: Tue Jul 22 17:52:08 EDT 2025
Powered by FUDForum. Page generated in 0.03885 seconds
