Home » Language IDEs » AspectJ » ERROR : export - plugin with aspectj support
ERROR : export - plugin with aspectj support [message #70655] Tue, 16 October 2007 07:11 Go to next message
when trying to export a plugin with aspectj support I get the following
('normal' plugin export - without aspectj support - works)
> An internal error occurred during: "Export Features".
> java.lang.NullPointerException
eclipse 3.3.1
ajdt 1.5.0.200706070619
full 'update' done
all help appreciated
Danny
Re: ERROR : export - plugin with aspectj support [message #70820 is a reply to message #70655] Tue, 06 November 2007 04:43 Go to previous messageGo to next message
Originally posted by: erdal.karaca.airbus.com
I have the same problem...
Using
- eclipse 3.3.0 I20070621-1340
- AJDT 1.5.0.200706070619
- AspectJ 1.5.4.200705211336
> eclipse 3.3.1
> full 'update' done
> Danny
Re: ERROR : export - plugin with aspectj support [message #71017 is a reply to message #70820] Fri, 21 December 2007 04:34 Go to previous messageGo to next message
Originally posted by: Jens.Borrmann.gillardon.de
I have the same problem, too. My configuration is the same as Danny's.
Interestingly, the problem also occurs if aspects are not used at all.
Any help/workaround?
-- Jens
Workaround [message #71077 is a reply to message #70655] Tue, 22 January 2008 09:36 Go to previous message
still the same bug (?)
tried with newest update:
Version: 1.5.2.200801212057
AspectJ version: 1.6.0.20080122011642
This works for me (when using rcp env as target platform which does not
have ajdt installed):
- temporarly switch your target platform to your eclipse installation
platform and export your plugins (important: it seems that exporting
plugins with aj support assumes that the target platform must have ajdt
installed)
(window - prefs - pde - target platform)
Re: ERROR : export - plugin with aspectj support [message #596496 is a reply to message #70655] Tue, 06 November 2007 04:43 Go to previous message
Using
> eclipse 3.3.1
> full 'update' done
> Danny
Re: ERROR : export - plugin with aspectj support [message #596568 is a reply to message #70820] Fri, 21 December 2007 04:34 Go to previous message
-- Jens
Workaround [message #596613 is a reply to message #70655] Tue, 22 January 2008 09:36 Go to previous message
installed)
Previous Topic:Weaving an aspect into single class in jar
Next Topic:Using AspectJ with PDE Builder
Current Time: Sat Nov 22 20:36:21 EST 2025
Powered by FUDForum. Page generated in 0.03977 seconds
